Old 12-01-2006, 11:47 AM
xleng is on a distinguished road
"A" Axis Substitution Macro Programming For Fanuc
I'm haveing problems rotating my 4th Axis at a ipm feed for simultanius work need help
Old 12-07-2006, 08:53 PM
theemudracer is on a distinguished road
I Have a Hyuandi-Kia with a 18I-TB with a sub-spindle. I have been playing around with that lately and the way I read the book, You have to specify in the parmaters which axis to operate in syncro. (Main or Sub) I think around 5460's....I dont think you can do it on both of them unless you load a parameter in the G10 mode and then change it back at the front of the program if your using the main also.
Jon
Old 12-07-2006, 10:17 PM
HuFlungDung's Avatar
Moderator
Is this like applying a 4th axis wrap, where Y moves are converted to A?
Old 12-08-2006, 06:53 AM
theemudracer
This A VMC I'm working on?
and HuFlungDung Yes but even if you don't move in the "X" I need to find a way to apply a feed rate to stay consistant with IPM?
xleng
Old 12-08-2006, 01:45 PM
Moderator
I would say you would convert your feedrate in a manner similar to the way you are converting your Y values to A.
To convert circumferential movements to degrees, you use
360/(2PI*R) as a scaling factor for the linear Y movements.
Part of that expression is obviously an unchanging constant
360/2PI = 57.29578
That happens to be called a Radian.
So in the imperial world, a feedrate of 57.29578 degrees/min will equal 1 ipm circumferential feedrate on the surface of a 1" radius cylinder.
For all other radii cylinders, the same factor, divided by the radius of the new cylinder, will give you an equivalent circumferential feedrate.
Eg.: to achieve 1 ipm on a 2" radius cylinder
57.29578/2 = 28.64789 degrees/min
The exact same procedure (using a scaling factor of 57.29578) will be applied to the Y axis movements to convert them to degrees. I am referring to wrapping a 2d map onto a cylinder.
If you are finding your A values directly by layout, then of course you do not need to convert the Y's to A. Otherwise you would apply the same scaling factor to the Y values, to a flat 2d map layout of the features to be wrapped around your cylinder.
Old 12-08-2006, 01:52 PM
Thanks I'll Give that a try
xleng
