Old 11-18-2006, 11:58 AM
bcdracing is on a distinguished road
10 10 10
when i put this program in my table starts heading to the corners.
i am new with gcode self learner but have come a long way.
here is my machine.
http://bcdracing.com/cnc/cnc.html
i got it cutting once then lost it.
minimal code is what i am looking for.
start and end at the same place
i'll set the height and run into the material.
thanks alex
N100 G20
N102 G0 G17 G40 G49 G80 G90
N106 X0. Y0. ZO.
N108 Z.5
N112 G0 G90 X-.3164 Y1.9337
N116 Z.1
N118 G1 Z0. F5.
N120 Y1.5587 F10.
N122 G3 X.0586 Y1.1837 R.375
N124 G1 X.3021
N126 G2 X.4356 Y1.1403 R.2269
N128 G1 X1.2751 Y.5297
N130 G2 X1.3686 Y.3462 R.2269
N132 G1 Y-.148
N134 G2 X1.287 Y-.3223 R.2269
N136 X-.0031 Y-.7661 R1.9182
N138 G1 X-1.8504
N140 G2 X-2.2348 Y-.3818 R.3843
N142 G1 Y-.2756
N144 G2 X-1.9685 Y-.0094 R.2663
N146 G1 X0.
N148 G3 Y.0094 R.0094
N150 G1 X-1.9685
N152 G2 X-2.2348 Y.2756 R.2662
N154 G1 Y.4056
N156 G2 X-1.8504 Y.7899 R.3844
N158 G1 X-1.4255
N160 G3 X-.3102 Y1.146 R2.1525
N162 G2 X-.185 Y1.1837 R.2269
N164 G1 X.0586
N166 G3 X.4336 Y1.5587 R.375
N168 G1 Y1.9337
N170 Z.1 F6.42
N182 G0 G90 X.2253 Y.7087
N186 G99 G81 Z0. R.1 F5.76
N188 X.9027 Y.2107
N190 G80
N194 X0. Y0.
N196 Z0.
N198 M30
Old 11-18-2006, 12:19 PM
JEST's Avatar
JEST is on a distinguished road
The first command of motion is X0 Y0 Z0
If you start the program with the machine elsewhere...
Is the machine heading X0 Y0 Z0?
Old 11-18-2006, 12:28 PM
JEST's Avatar
Are you starting the program with the machine at X0 Y0 Z0?
The first motion command is to go XYZ 0.
Is that the "corner" it moves to?
Old 11-18-2006, 01:06 PM
when i turn the machine on its @ 000.
it heads towards the right and back.
can you exsplain the where the 3 000 are. absolute, ? , ? i forget and don't
really know how it works. or link me to a page that exsplains it.
alex
Old 11-18-2006, 01:34 PM
JEST's Avatar
N100 G20
N106 X0. Y0. ZO.
G0 Rapid Linear Interpolation
G20 Inch Mode
G17 X-Y Plane Selection
G40 Tool Radius Compensation Cancel
G49 Cancel Tool Length Offset
G80 Fixed Cycle Cancel
G90 Absolute Mode
The machine is told to Rapid to X0 Y0 Z0 (Absolute)
Do you know how to enter data (MDI)?
towards the right and back.??
What quadrant is that for your settings?
Are you sure that the machine is not set up to program in the -X -Y quad?
Old 11-18-2006, 04:18 PM
[QUOTE=JEST;2193
[/QUOTE]
MDI, the screen on the cnc, yes i do.
is there a place to edit the where 000 is from the machine.
where ever i turn it on it reads 000.
thats where it goes to if i start the program in the center.
? you need a xy for the right and back?
don't know what that is.
thanks alex
Old 11-18-2006, 04:32 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
here is my machine.
thanks alex
N100 G20
N106 X0. Y0. ZO.
N108 Z.5
N116 Z.1
N118 G1 Z0. F5.
N120 Y1.5587 F10.
N124 G1 X.3021
N132 G1 Y-.148
N138 G1 X-1.8504
N142 G1 Y-.2756
N146 G1 X0.
N150 G1 X-1.9685
N154 G1 Y.4056
N158 G1 X-1.4255
N164 G1 X.0586
N168 G1 Y1.9337
N170 Z.1 F6.42
N188 X.9027 Y.2107
N190 G80
N194 X0. Y0.
N196 Z0.
N198 M30
First, this should be a number, not an uppercase letter "O". (easy typo)
Look at line #3:
ZO.
Old 11-18-2006, 04:33 PM
Switcher's Avatar
Moderator
Get www.ncplot.com to help verify your g-code before running the code on your cnc machine (Free Demo).
Old 11-18-2006, 04:41 PM
JEST's Avatar
Ok. Lets backup.
The Gcode has no visable starting "errors"
So lets look at location and motion control.
Input G01 X0 Y0 Z0.
Not G00! G00 is RAPID. Use G01 (feed) if you must enter a motion command and you are not POSITIVE of the machine response. Also be ready to hit stop or interupt.
What happens when you execute?
Old 11-18-2006, 07:40 PM
Walt@SGS.Inc is on a distinguished road
I think with G01, you may need a F something. F10.0000????
Walt
  #11   Ban this user!
Old 11-18-2006, 07:56 PM
JEST's Avatar
good call Switcher.
I see the letter "o" where the number zero belongs.
Great machinist eye for detail!
Ashamed I overlooked it.
I did notice the "even only line numbers. N104,N110,N172,N174,N176,N180,N184, and N192 have been removed.
Is this the result of text based editing?
  #12   Ban this user!
Old 11-18-2006, 08:17 PM
Blaster33442 is on a distinguished road
drop the line N106 & N108 should keep it from running into the work
