| G-Code Programing Discuss G-code programing and problems here! |
| Since you got the right answer, you probably figurred it out. On a metric tap, the pitch is designated after the diameter. The difference being that on a standard thread, the pitch is threads per inch. So, just take any metric pitch and divide by 25.4, you have the inch conversion. If you program for IPR, you have your answer. Multiply by RPM if you feed in IPM and run.
__________________ It's just a part..... cutter still goes round and round.... |
| That good if you are running in inch mode. but if you are programming in metric mode, what is the MM per min. I just started learning learning how to program a Tree 325 Mill. I can convert inch to metric but not sure how to program speed and feeds for metric tapping cycles. M8, M10, etc. |
