| G-Code Programing Discuss G-code programing and problems here! |
| I am using the Cincinnati Milacron Sabre (vertical cnc mill). I've looked through the manual but havn't found the best method to do this... Id like to program one piece and (using a subprogram?) have it repeat all the toolpaths a number of times, offsetting it in X and/or Y a desired number of times. I'd like the operator to be able to adjust how many times it repeats the subprogram. This is an example of the program that I ran and it works... % (REPEAT TEST) :0 G0 T1 M06 N30 M01 N40 G0 H0 X3 Y3 S3000 M13 N50 G0 Z6.0 N60 (DFS,L22) N1040 G1 Z5.0 F40.0 N1070 X4.0 N1080 Y2.0 N1090 X1.0 N1100 Y3.0 N1110 X3Y3 N1120 G0 Z6.0 N1130 G92 X0.0 N1140 (ENS) N1150 (CLS,L22) N1160 (CLS,L22) N1170 (CLS,L22) N60 G0 Z15.0 N70 H0 X0.0 Y20.0 N80 M52 M02 % DFS defines subprogram called "22" ENS ends subprogram "22" CLS calls subprogram "22". What this program does, as it is, is calls up sub "22" 3 times (since N1150, N1160, N1170 all call sub "22"). Unfortunately, to make it user-friendly for the operator, I need to call sub "22" about 50 times for this job. I know on other machine controllers, there is a "Repeat" code called L where you would program it like this: N5000 M98P22 L50 (this calls subprogram 22 50 times)... Does anyone know how to achieve something similar on the Acromatic? The L word isn't used to "repeat" as on other controllers. |
| Burnt Hills Initilize a counter Call up the subroutine Increment the counter +1 Test the counter > 50 If true skip to end LOOP Back to Call subroutine END All of that is covered in the programming manual. If you can't find it send me an Email GWood@gbicincinnnati.com Thanks G.Wood |
| (cls,l22,50) ?? |
Thanks for your reply! I do have all the manuals for the 850SX and I did realize that using a macro would be the best way to handle this. I could not find the format for making a loop macro for the 850SX controller. We use Smartcam at our company and it's no problem to copy/paste geometry and to assign toolpaths to it but we found that our machine is limited in memory and without macros, there are some jobs that are limited. My goal was to have, for instance, one variable they can change to adjust the "number of repeats". I saw in the 2100 manual that it accepts (CLS,Lxx,50) to do 50 runs but 850SX did not accept it. It seems every controller has slightly different commands for using macros and I havn't untangled that issue yet. I could not find any help on using macros in the 850SX manuals. Any advice/help would be greatly appreciated! |
| Q50 G10=[T1]V[AOF,1,X].......SETS TEMP VARIABLE TO ASSIGNABLE OFFSET NUMBER OF PARTS G11E[T1]-[T2]>.1L100.... CHECKS TO SEE IF T1=T2 G11L200 Q100 G10=[T2]V[T2]+1......SUBROUTINE COUNT ADD 1 (CLS,L20) G11L-50 Q200 G10=[T2]V0 M2 (DFS,L22) (ENS) I UE ASSIGNABLE OFFSETS BECAUSE YOU CAN CHANGE THEM WHILE THE MACHINE IS RUNNING ON THE MILLING THE ASSIGNABLE OFFSET IS FOR H# IN PROGRAM MAKE SURE YOU USE A PROGRAMMABLE OFFSET YOU ARE NOT USING IN YOUR PROGRAM IF YOU LOOK IN THE TEMP VARIABLE LIST YOU CAN SEE WHICH PART YOU ARE WORKING ON!! I USE .1 BECAUSE TEMP VARIABLES SONETIMES WILL USE 1.9999 AS 2 I DONT KNOW WHY G11E[T1]-[T2]<.1L100 [T1]=# OF PARTS YOU NEED TO MAKE [T2]=HOW MANY PARTS HAVE BEEN STARTED ANY QUESTIONS YOU CAN E-MAIL ME AT CNCA2100@TRUVISTA.NET HOPE THIS HELPS HERMAN |
