Results 1 to 9 of 9
Thread: Cam design???
    Registered anoel's Avatar
    Apr 2003
    Central Illinois
    Cam design???
    I've been looking around for a cam design reference. But can't weed out the "CAM" out of the search engines.
    I'm looking for some general guidelines as to what different cam shapes do and how to design a cam for a particular need (what ever that might be).
    Can some of you machinist/engineer types point me in the right direction?
    Nathan
    Oct 2003
    Lincolnton NC USA
    Nathan
    I have a dos program called camz. It is a great program form designing cams.
    Registered buscht's Avatar
    Nov 2003
    The Machinery's Handbook has a section on cams and cam development. You can get this book used on Ebay fairly cheap.
    Oct 2003
    Lincolnton NC USA
    I found it! If you are interested in camz. You can find it @ glasshouse software. under products / CAMZ is an opp. with this program it will write a program of points (x,y) you can use as a subprogram. It uses sign curve as an opp. This may or may not help you but here it is.
    Registered CHAD's Avatar
    Mar 2003
    ANALITIX CAM DESIGN
    I USE A PROGRAM CALLED ANALYTIX. IT WILL GIVE YOU ANY TYPE OF CAM YOU COULD IMAGINE. IT OUTPUTS A DXF FILE THAT YOU CAN IMPORT INTO A CAM PACKAGE TO WRITE THE G-CODE. IT MAKES VERY ACCURATE AND VERY SMOOTH CAMS.
    Apr 2003
    Central Illinois
    Well, the Analytix looks cool but I ain't paying $199 for a special purpose program like that for home use.
    I can draw a cam in CAD with no difficulty. What I'm after is information on HOW to design cams for different functionality...
    Nathan
    Dec 2003
    Nottingham, England
    Nathan,
    Check your email.
    John S.
    Jan 2004
    Norway
    Hello!
    Buy this book, there is an evaluation software included:
    Robert L. Norton:
    Cam design & manufacturing handbook.
    www.industrialpress.com
    Regards
    John
    Apr 2003
    Central Illinois
    Thanks Guys. I think that I've got what I need now...
    Nathan
  • Posting Permissions
