Old 10-02-2006, 11:10 AM
CatCAD is on a distinguished road
G112
Hello! I apologise in advance if this is a stupid question, but I have hit a stumbling block! I am trying to use codes G112 and G113 on a Fanuc O-T operated lathe. But when I enter the codes it comes up with Undefined code! What am I missing, as I am sure it should be able to use these commands. Any help you can provide will be greatfully recieved.
Many Thanks
Old 10-02-2006, 11:49 AM
ajl6549 is on a distinguished road
g112 and g113 I believe are optional interpolation codes. Check the manual to be sure though.
Old 10-03-2006, 09:31 PM
CNCRim's Avatar
Try G12.1(G112), and if it is still not working check your machine parameter.
Old 10-04-2006, 02:39 AM
I have tried 12.1 and it still does not work! I am new to this lathe and fanuc O-T. What machine parameter should I be looking at?
Many Thanks for your help
Old 10-04-2006, 06:33 AM
*Registered User*
Bluesman is on a distinguished road
Need Cash
You don't have the Polar Interpolation option, It is a 9000 parameter that Fanuc will charge you about 2500.00 bucks to come in and turn it on. I do not have that particular one or I would givie it to you. But some one on this sight may have it.
Do you have the live tooling with a programable C axis? depending on the MB some of those types of machines come with the Polar interp standard and othrs it is an extra option
Bluesman
Old 10-04-2006, 07:17 AM
Hello Bluesman!
Yes I have the Live Tooling with a programable C-axis. Is there somewhere that I can check if this 9000 parameter is included on my machine?
or
If any one does know of said 9000 parameter ..... and would be willing to share I would be extreemly grateful.
Thanks again
C@
Old 12-04-2006, 04:12 PM
Capt Crunch is on a distinguished road
hey
i have a yama seiki with live tooling with a Fanuc Oi control. look at system parameters 5460=1 and 5461=3. these are the settings on my lathe. best of luck
