Old 09-30-2006, 09:28 PM
bbergami is on a distinguished road
Setting z
I just finished setting up a touch plate to home my z axis. It is .375" thick. I wrote a script to raise the bit by .625" which puts the bit +1.00" above my material. What g code and syntax do I use to reset the Z reading to 1.00" instead of .625".
Bert
Old 09-30-2006, 11:49 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
What CNC Control and Machine Tool Brand ?
If it is a Fanuc or Yasnac you will be using a G43 H? (H1 = Tool Offset #1 and H2 = Tool Offset #2)
You can also use a G44 but the standard in the industry is G43.
It would help to know the first question above though.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 10-01-2006, 12:21 AM
I'm using a DeskCnc controller on a homebuilt router.
Old 10-01-2006, 02:13 AM
tobyaxis's Avatar
Moderator
Sorry I don't know anything about that application. Someone that does will stop in soon to help you.
Toby D.
Schwarzwald
Old 10-01-2006, 08:21 AM
Thanks Toby. I'm sure it's something simple. All I'm trying to do is set the z coordinates to 1.00".
