Old 12-29-2003, 03:38 PM
Scott_bob's Avatar
Mfg Engineer
Scott_bob is on a distinguished road
Rapid to (# set by Parameter) What's yours?
During G83 peck drilling rapid motion returns to +____
This positive distance from the last feed depth is set by a parameter on your Fanuc control.
#532 on an OM control
This parameter is set by most factorys at 1000
or .100 thousands
That is way too much if you are drilling with small drills.
Smaller drills are programmed at lower feeds and the time wasted, feeding thru air can really add up.
If you do much drilling at all, check this setting...
Before you do, get a cycle time of commonly drilled holes and see how much time you'll end up saving, you'll be amazed!
I think this setting should be set at 200
or .020 thousands
or 100 (.010)
The Fadal control uses a P_ value to set this distance in the G83 line of code.
Fadal default is zero. This means that Rapid motion returns to the last peck depth. I believe a little clearance here is best in the event of a chip falling back in the hole... I use P.010
Scott_bob
Old 12-30-2003, 08:59 AM
E-Stop is on a distinguished road
I use .020 for the rapid return. The boss says I should use .005 to .010 to reduce the cycle time. Let's see, a drill moving at 8.5 IPM will move the extra .010 in about 1/15th of a second. Not much savings there compared to a tool breaking and the time it takes to replace and re-set the tool.
Old 12-30-2003, 11:06 AM
Scott_bob's Avatar
Mfg Engineer
E-stop,
Do you know what your CNC was set at the factory?
Scott_bob
Scott_bob
Old 12-31-2003, 07:53 AM
Yes. The factory setting was .050, which is a good, safe place to start.
Old 07-19-2004, 10:04 AM
Oneil is on a distinguished road
E-Stop,
0.05 is fine, If you want to save time invest into some premium drills that cut faster.
Old 07-12-2009, 08:34 AM
Suraj is on a distinguished road
peck drilling not possible
dear friends
i have a Fanuc Oi Mate Series control on my VMC.
i want to drill 50 mm deep drill with 5 pecks.i have used G83 but its not working.
please tell me which parameter to edit to start the peck drilling.
its really urgent i am loosing my 50% extra time in drilling.
thanks
Suraj.
Old 07-12-2009, 10:09 AM
dcoupar's Avatar
What do you mean "it's not working"? What does it do? Do you get an alarm? If so, what alarm? Does it drill but not peck? Post your G83 line here so maybe we can help you.
Old 07-12-2009, 11:11 AM
hi
hi
thanks for replying.
the problem was no pecks during drilling.
but i found the parameter by myself
its 5114
i have one more problem. please let me know how to use to coordinate codes like G54 and G55, G56, G57 In same program in absolute G90 cycle to use different origin.
thanks.
Old 07-13-2009, 08:05 AM
stevo1 is on a distinguished road
It's very easy to do. You set the G54-G59 to the position that you want to reference. Take the machine position numbers of were you want to orgin and put them in the work coordinates G54-G59. Say it is in G55...now all you have to do is make sure you use G55 in your program. G0G90G55X0Y0.
These will act as any other G-code. They stay modal until changed or rest of the control. Most Fanucs default back to G54 when reset.
Stevo
Need Bridgeport EZ-Track G-Codes to build post soweebee Bridgeport and Hardinge Mills 13 01-28-2006 02:10 AM
Running a set number of parts? Shizzlemah AjaxCNC Control Products 2 05-02-2005 07:47 PM
Parameter Fanuc System10T saptoro General Metal Working Machines 0 03-21-2005 08:38 AM
How do I set Parameter 592 for G 83 Cycle Farmer G-Code Programing 4 11-26-2004 11:13 PM
How to set up Tool Offset in MACH2? High Seas Mach Software (ArtSoft software) 7 09-09-2004 01:54 PM
