Mach3 has a "surfacing" wizard
This is probably a really dumb question, and I'm brain dead at the moment.I need to mill a surface 6" x 10" flat with .125inch end mill. Is there a quick and dirty way to generate the code for Mach3? Dept of cut I would handle via multiple iterations of the same code.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
g32 z-0.25 y6.2 x10.2 i.1
I used the Probe Cycle command, in TurboCNC, to mill a surface.
This line does multiple 0.1" passes, to a depth of 0.25".
It also covers an area 0.1" larger, all around, using a 0.1" overlap.
G00g90x-0.162y-0.038
G00g90z0.
G01z0.f100.
G01g91z-0.
G01g91x0.112
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.104
G01g91x10.05f100.
Y0.104
X-10.05
Y0.098
X10.05
G00g91z.100
G90x-0.162y-0.038
Z0.
M99
Why would he need to use a 1/8 endmill?
-He broke all the other endmills.
-The largest shank allowed in the spindle is 1/8"
-The spindle only has .01hp driving it.
-The spindle runs at 100,000 rpm and 1/8" on down are the only ones that won't burn up.
-He likes the sound of the router motor screaming for hours on end while he gets a few winks of shuteye....the 'white noise syndrome'.
-Setting a new record in Guiness for "largest surface planed with a 1/8" endmill."
Thanks guys, I figured out the mach3 wizard. Worked great.
Hi pminmo,
I haven't figured out the mach3 wizards, when I type in a number it changes back to some default number. I switched from Qstep to mach 3 and haven't used mach enough to know how it all works yet I used kippware for the above g-code.
mitch
Thanks Gerry
That was it![]()
Yep, I learned the same lesson fooling with the wizzards. Couldn't find anything in the documentation. Then all of a sudden something worked, scratched my head as to why, then a couple of more trys and got it. Wow something so simple was so elusive. Guess too many point and clicks in my brain!
I gave up because I thought it was a option that i didn't have, them wizzards look pretty handy.
Whats wrong with using the jog keys in mdi mode?
