Old 08-30-2006, 01:17 PM
Navigator is on a distinguished road
Macros.How to work with it?
Hi. I'd like to start working with macros,but don't know how. If anybody knows something on this subject please give me an advice. Thank you in advance for any information on this matter.
Old 08-30-2006, 02:24 PM
psychomill is on a distinguished road
What control? If you have a FANUC (and others do as well) programming manual, it has some simple examples of macros and functions to start with. The rest of it, live and learn....
You can download lots of written macro programs online from many sources. These may be hard to follow but might give you the idea once you understand the basics. Not sure if there are more basic macros available online to go through with you step by step unless you pay for it. Someone might know though....
It's just a part..... cutter still goes round and round....
Old 08-30-2006, 03:14 PM
Thank you for reply. That is the problem,I can't catch basic yet. Do you know any sources about macros?,I couldn't find... For example Some words like NE,FUP,LT what does it mean? I have Fanuc GE 0M series and I wouldn't say it's the best to learn macros with it... Old scrap. Manual is from another machine and the first problem I've faced is how to type them in? It doesn't accept #variable sign in a front of line only after any other sign,why? Brackets,can't find how to print them,"shift" is not very helpfull... so you see,I'm in the sea and where have I swim to... Help,I'm sinking...
Old 08-31-2006, 01:21 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Learning Macros is a bit tricky and NCPlot offers a Macro Calculator where you can write and execute Fanuc Macros. There is also a Help file that explains the basics. This may help you.
www.ncplot.com
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-31-2006, 09:28 AM
I'll try to touch on some here....
NE : Not Equal
FUP : round up
LT : Less Than
here's some others that are common...
GT : Greater than
LE : Less than or equal to
GE : greater than or equal to
ABS : Absolute value (drops the negative "-" sign)
FIX : round down
EQ : equals to
And there are others but this will get you started. Some examples.....
'IF' and 'GOTO' statements are the most common usage of macros.
IF[#503EQ#100]GOTO3333
which means, If variable 503 is equal to varable 100, then go to 3333. In this case, the program jumps to (searches) for a line number "N3333" and starts from there. You can also use real values.....
IF[#500EQ2.653]GOTO200
And for negative values...
IF[#500GT-1.500]GOTO200
Other math.....
#100=4.0 (you can use an "=" sign here)
#101=2.0
IF[[#100/#101]EQ2.0]GOTO300
N300
No, the OM is not the best and its a pain in the arse to type in commands. I haven't seen an OM board in 15 years so I'm not much help for you in getting macros to work on that board. Maybe someone else will ring in and give you some pointers on typing them in on this board...
Old 09-01-2006, 05:55 AM
gar gar is offline
gar is on a distinguished road
060831-2048 EST USA
Navigator:
The word MACROS in the CNC field really means additional functions added to the basic G-code language (MACROS are an extension of the language). This is quite different than the meaning of MACRO in the computer field.
My reference is HAAS and this is largely based on Fanuc. HAAS MACROS add math functions, formula calculation, assignment of values to variables, logical operations, subroutine calling with parameters, access to many internal variables in the machine, and DPRNT capability.
On-line you can access the HAAS web site and download a copy of either or both the mill and lathe manuals. In the manual there is a section MACROS.
www.haascnc.com , site map, customer service, manual updates scroll down to mill 96-8000 and pick this. It is a 12 meg file. or directly
http://www.haascnc.com/customer_serv...mc/96-8000.pdf
If you go directly to this address you get a mostly blank screen in Internet Explorer and a long wait. At the lower left you will see the progress.
HAAS page 80 is the start of MACROS (Adobe p 87 of 213), search for "Macros add capabilities and", but do not use the double quotes.
FIX[] obtains the interger portion of a decimal value in HAAS and produces an integer value. This is quite different than ROUND[].
The HAAS MACROS chapter is also where you find a limited definition of many #-variables.
Your capability is greatly enhanced with MACROS.
Old 09-02-2006, 12:47 PM
Thank you very much... Now another question,if I can't find brackets sign on the operational panel ([) does it mean that macros unavailable on that controler type? It's GE Fanuc 0M series but it has macros options I've checked that.
Old 09-02-2006, 12:51 PM
tobyaxis's Avatar
Moderator
The brackets may be in the Variable Listing Screen Window executed by a softkey.
Toby D.
Schwarzwald
Old 09-02-2006, 06:42 PM
You are a great man Tobyaxis,thanks. I sitting now in a front of monitor and try to think up where to use these macros,I mean what the benefits I would get of it? Using them instead of main programme or support the main programm, what the application it could be used for? I know only one at the moment, it;s bolt holes circle. But it means that for every new group of parts I will have to change variables while main programm is permanent... I know that with macros I can get big support,but I'm just thinking where and how... Don't be cross with me,I'm a beginner yet... Very simple manufacturing,small workshop and lack of information...
Old 09-02-2006, 11:24 PM
tobyaxis's Avatar
Moderator
I'm not that Great. I just look for the simple answers and ways to do things. Now I'll be honest, I never use Macros for anything that a Sub-Program can do. Subs can be applied to any program without changing Variables. Unless your doing a family of Like parts or complex geometry like End Mill Grinding you won't need macros. Plus I use CAD/CAM.
Toby D.
Schwarzwald
  #11   Ban this user!
Old 09-03-2006, 09:27 AM
gar gar is offline
060903-0818 EST USA
Navigator:
Here are several specific links with my perspective based on HAAS machines:
A tool change subroutine that requires MACROS.
http://www.cnczone.com/forums/archiv...p/t-12545.html
MACROS used to eliminate a long list of IF statements.
www.cnczone.com/forums/printthread.php?t=12158
Next is a sort of useful discussion because it addresses inadequate definitions.
http://www.cnczone.com/forums/archiv...p/t-14613.html
A long discussion, but if you can follow thru there is useful information.
http://www.cnczone.com/forums/archiv...p/t-20564.html
  #12   Ban this user!
Old 09-03-2006, 10:16 AM
bob1371 is on a distinguished road
We use macros to track tool life counters.
To monitor machine idle time. If idle x amount of time first cycle will run warmup program x # of times then goto main program and cut part. This works well on several lathes we do small parts on. When the operator returns from break the first couple of parts would be bad before doing this macro. We have it set up to track time and account for daylight savings and leap year.
Bob
