| G-Code Programing Discuss G-code programing and problems here! |
| The shop I work in has this turning center and no one has been able to figure out how to use or what drilling cycle to use as canned cycle for this machine. I would like to be able to use a G83 to get the chip out and the coolant in. The problem is when I type in G83 it appears on the monitor with all that's needed for that canned cycle but when I try to run it I get a alarm about unrecognized g code. It does work with g74 but not a good cycle for just running twist drills without thru coolant. We're not a big production shop mainly build specialized machines and small production runs. I wouldn't want to have to program Z +- everytime I need to drill holes, I can't believe this machine doesn't have a good drilling canned cycle. Any help is appreciated. |
| If you have macros you can use this. You can adjust the pullout and return to be feed or rapid as needed. #103=1.0 (FINAL DEPTH OF DRILL) N12(5/64" DRILL) #101=.02 (1st peck amt.) #102=.04 (each peck amt.) S800M13 (rpm + coolant on) S1500 T1212 G1X.8Z-.02F.03 X0 (PECKING CYCLE) WHILE[#101LT#103]DO1 G1Z#101F.0008 (drill) G1Z-.02F.03 (pullout of part) G4X.5 (let cool) G1Z[#101-.01]F.03 (return into part .01 away) #101=#101+#102 END1 G1Z-.02F.03 G4X1.0 X1.4 T0 S1000 G4X.5 S500 G4X.5 M0 |
If you don't want to use a macro try this. G97S750M3 G28U0W0 T404M8 G0G40X0Z1.0 Z.1 G83Z-2.0R.1Q2000F.009(or Q.2)> peck amount in Z G80 G40G0Z1.0 G28U0W0 This depends on the year of the control. A Fanuc 10T from 1987 has Drilling Canned Cycles
www.ncmanager.com |
BTW: you can use a sub-program as well M98P????L????
