| G-Code Programing Discuss G-code programing and problems here! |
I have just finished building a CNC machine. Mechanically t works wvery well. I have downloaded the Mach3 demo software which is also working as it should. Howeve, I have a problem with G-Code files. I have drawn a template (45 mm square with four 4mm holes at each corner) with CorrelDraw ver.8 and saved as a plt file. When I load this into Mach3, the G-Code produced is dimensionally wrong!. The X and Y values are in the order of 1 or 2 units. Shouldn't it be 45 as I have drawn it?and cut I get a small movements in the X and Y axes. It isn't the machine, for when I manually enter a G-code instruction it works fine. For example, if I enter "G0 X50" the X axis will move 50mm. Can someone throw some light on this matter. I have absolutely no knowledge of G-Code programming. Thanking you all in advance Jock |
| Is there an option on the import for metric units? If so, try turning it off (or on) and see if that helps
| Thank you to everyone for coming to my rescue. I have imported Motomitch's file and it work as it should. I noticed that G-Code genrated from his file gave a X and Y value of 45. With my file it gave a value of 2.2 for a value that should be 45. The fact that Motomitch's file generated the correct value must mean that the scaling was not on. Thinking that maybe the dfx file I generated was incorrect, I used DeskEngrave to create three letters (ABC) at 72 pts, which translate to 25.4mm in height. Imported it in Mach3 and yet again the G-Code was wrong! So where did I go wrong ? Thanks again to all the help |
| Post the .dxf and we can see what size the .dxf is.
| Sorry Switcher, I was going to say in my earlier reply that I am not able to sendng to the G-Code file. In a hurry to response to everyone's help I forget to mention it. Being wrong I deleted it, if you think that the G-Code may throw some light I would be happy to re-generate it and sent it on. Thanks Jock |
#12
| Don't know why G-Code didn't get sent. Here it is- Switcher, if you look at it you will find the X and Y values are way out. I imported the dfx file into Mach3 and generated the code. Juat as I did with Motomitch's dfx, except his came out right. |
