Quick backround... been running, setting-up and milded programing for cnc lathes for around 8-9 years in a production shop. A week ago i was tossed on a TOYODA FA550-II Horizontal Machining Center. Aside from simple stuff on a Bridgeport and Milling slots and bolt-hole pattens on a HITACHI-SEIKI HI-CELL 23 i have just about no Mill experience.
So my question is![]()
How would you go about writing a "ramp on" path to face a 7.5in flange with a 3.5in bore through it.
Heres how they have it set up now but its creating a crap finish.
The finish only has to fall between 93-125 but can not have any draw or ramping marks on it.
Z.0 = finish depth.
X.0 = center line of flange
Y6. = clear rapid point above part.
Using a 4" face mill (EDIT: miss-labled as fly cutter before, sorry) with six inserts on Gray Cast Iron.
Orginal code...
Heres how i butched it to get a pretty good finish.Code:G0 Y5.5 X-3.25 S600 Z.25 G1 Z.0 F25.5 Y.0 F30. (feed onto part) G3 X-3.25 Y0. I3.25 J0. F30. (rough) G3 X-3.25 Y0. I3.25 J0. F30. S1000 (spring pass) G0 Z.75 G53 ....
I was trying to ramp on the part but keept gettin an alarm abuot radios is wrong, think it said it was too big or somthing...Code:G0 Y5.5 X-3.25 S600 Z.25 G1 Z.005 F15. Y.0 F30. (dont like this, want to ramp on with a G3) G3 X-3.25 Y0. I3.25 J0. (rough) G0 X-5.75 Z.032 (dont like all this eather, want to ramp off) G1 Z0. S1750 F47.5 X-3.25 G3 X-3.25 Y0. I3.25 J0. (finish) G1 X-3. Y-1.5 Z.001 (dont like this, want to ramp off cleanly) G0 Z.75 G53 ....
I dont have a full understanding of the J, I and K values for a G3 right now which seams to be my problem.Code:G0 X.0 Y6. Z.25 S600 (rapid above and to center line of flange) G1 Z.005 G3 X-3.25 Y.0 I.0 J-6. F30. (Ramp on but get an ALARM) G3 X-3.25 Y0. I3.25 J0. (rough)
Think i see when your making a full circle X goes with I and Y goes with J and ill guess Z goes with K but im lost with partial circle.
Guess my bottom line question is how do you make a partial circle with a G3 to ramp on and off a part ?
Thanks for any help or advice.
- joe
_
LinkBack URL
About LinkBacks
; go and pull up my posts in other threads and you will see why.
cant undersand how little can get done with all the "bosses" walking around
been working nights for over ten years now and never understood that. Its all good between me and my partner, hes a good guy.
