Old 04-28-2006, 09:51 PM
Heavy D is on a distinguished road
Question Possible to write variables to a program?
Is it possible to have the program write the contents of a variable into a program on a Fanuc control (16i, 18i)
I have a probing program that takes some points on the casting and then calculates all the work co-ordinates for all the B-axis rotations. There is one value that is measured, stored in variable #700 that needs to be logged for every part. This is currently done by hand. What I would like to do is have the program dump the variable into a file or program in the machine and just copy the file/program every week. we don't have a DNC system so it needs to be store in the machine until I can remove it with the memory card.
I know on a Makino Pro3 control, the tool files (all the tool data) can be output into a program on the machine with an M code. But that data is in the custom pages and a pro3 is a different animal then a normal fanuc 16 control.
any thoughts, ideas are greatly appreciated
dan
Old 08-21-2006, 10:53 PM
WildBill9000 is on a distinguished road
You should be able to store the measurements to tool offsets or common variables, but I dont know how you get them off of the control without backing the whole thing up. There is no way to change strings in a program through another one.
With Okuma there is a way to have it print (output) to an external device, i would assume fanuc would have something similar. I will root around in my fanuc manuals tomorrow if i remember.
Old 08-21-2006, 11:08 PM
ah cool, dont even have to root through those darn fanuc books!
http://www.cnczone.com/forums/showthread.php?t=9816
