Old 02-08-2006, 01:38 PM
avieritei is on a distinguished road
Red face WEDM -gear software
DO you need a special software to generate CAM programs for gear parts ?
any suggestions?
Old 02-08-2006, 03:17 PM
Wilabee is on a distinguished road
We have used BobCad-Cam Version 19 Wire EDM software several times to cut gears without any problems.
Old 02-08-2006, 03:35 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
avieritei
I haven't tried this software - but seems straight forward is it meets your need:
http://www.realhamradio.com/gearhome.htm its only 50bucks so might be a cheap investment. I'm considering - but my wallet is a bit empty just now...
It looks unteresting because it goes from gear design straight to gcode. No intermediate steps if all you want is a SPUR gear. Note: it seems set up for milling a gear not using a hobbing tool (as I understand more accurate, faster, etc).
Also, there are plug-ins for Rhino and SolidWorks too. Haven't tried those either but seems like a member on the zone wrote/used the Rhino script.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 02-19-2006, 05:23 PM
Salty72 is on a distinguished road
what types of gears are going to be cutting - I think I have a program (uses MS excel) that was given to me to cut flat gears if this helps
Old 02-20-2006, 05:34 AM
yes flat gears I must cut
Thank you .
Old 04-11-2006, 07:50 AM
sorry for the delay
here you are
Old 04-11-2006, 08:07 AM
I tried to post the XLS file as an attachment but it doesn't seam to have taken if you send your E-Mail I will forward
one last try as a zip
Old 04-11-2006, 10:12 AM
*Registered*
lakeside is on a distinguished road
the one thing that bobcad did with version 21 was improve the gear function
Old 04-13-2006, 11:31 AM
Talking Many thanks
Thank you every one for your support!
It really helped me a lot !
Old 06-06-2008, 05:03 PM
AngelT is on a distinguished road
I need the gcode for a 60 teths and 8" diameter to be used on CNC router 3 axis...thanks I uses the 6T Gear.zip program but it seems to have aproblem with line 4...gives me a error..
