Old 01-04-2006, 09:07 AM
soarnut is on a distinguished road
complete idiot help here please
Folks
Am trying to get my router working with "Quickstep" and the pulse pacer attachment. I was using a french software called Ninos but no matter what I could get no speed out of the machine. 3mm's is painful to watch. Any way the Ninos did all the G code conversions for you and actually functioned very well in that respect. The quickstep uses ACE converter. This seems to generate the code OK but it may be anywhere on the planet. Usually completely off the cutting surface. Also the machine is set up to the program in metric (centimeters) and the code is seeing each segment in the drawing as a centimeter, not a mm so it is giant. Surely one can't have to reposition each peice and run as G51.1 to get a cut?
Totally confused
Denny
