Do you mean an ellipse?
An oval is two half circles with straight lines between them. Two G2's and two G1's.
I've been playing around with the G02 command using emc2 sim mode, but I don't see a way to do an oval. How would you make an oval?
Thanks,
Alan
You can either simulate an ellipse with multiple arcs or you can write a macro that will calculate the elliptical points down to the resolution of your machine. Either way, you need to be fairly knowledgeable and practiced on your math skills.
http://www.kirkcon.com/
I draw it in AutoCAD with arcs and create the code from that.
Hi Alan,
Here's an example of how to machine an ellipse using User Macro. The resolution of the ellipse is achieved via variable #4.
Regards,
Bill
O0021
N1 G00 G17 G21 G40 G80
G91 G28 Z0.0
G28 Y0.0
T01 M06
S1000 M03
G90 G54
#1=100 (X RADIUS)
#2=50 (Y RADIUS)
#3=0 (START ANGLE)
#4=50 (NUM OF POINTS)
#5=360/#4(ANGLE INCREMENT)
#6=0 (COUNTER)
#24=#1*COS[#3]
#25=#2*SIN[#3]
G00 X#24 Y#25
G43 Z10.000 H01
G01 Z1.000 F1000.0
G01 Z-5.000 F100.0
#6=#6+1
#3=#3+#5
WHILE [#6 LE [#4] ] DO1
#24=#1*COS[#3]
#25=#2*SIN[#3]
G01 X#24 Y#25 F300.0
#6=#6+1
#3=#3+#5
END1
G00 Z10.000
G91 G28 Z0.0
G28 Y0.0
M30
Thanks everyone!! I'll try out that code Bill!
Alan
As long as the long axis is X or Y, you can change the scaling on 1 axis, then just program a circle.
Easy in MAch3. Not sure about emc2 though. Never used it. Never wanted to. Probably never will.
Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
here is an example written for linuxcnc.
LinuxCNC Documentation Wiki: Oword
I have not tried it...
sam
Thanks a ton for this, I mean really, a ton. It's useful little goodies like this that make me ok(ish) with not using software to write programming. I came up with a hole boring sub with variables like the program you have here, and I was far happier than I imagine I would've been had the code just gotten thrown at me.
