| G-Code Programing Discuss G-code programing and problems here! |
Hello everybody... I'm taking a manufacturing course where we are introduced to CNC Milling. I have a lab report due today, and while I was searching online, I found cnczone.com. I hope you can give me some help. I've got the following code, and I have to explain the functions for each block. Would you be kind enough to take a look at it and correct me if i'm wrong. Also fill in a couple of blank ones? Thanx! Code: (DATE=DD-MM-YY - 07-11-2005 TIME=HH:MM 09:15) N100 G20 # Inch mode N102 G0 G17 G40 G49 G80 G90 # Select the X-Y plane, turn off the path compensations, canned cycle and start absolute programming (1/4 FLAT ENDMILL TOOL-2 DIA. OFF. – 2 LEN. – 2 DIA. – .25) N110 T2 M6 # Change to tool 2 N112 G0 G90 X0. Y0. S3200 M3 # Spindle clockwise at a speed at 3200 RPM N114 G43 H2 Z.25 # Initialize tool length compensation at a 2 inch height and bring the tip of the tool to the position Z.5 N116 Z.1 # spindle stop and return to N118 G1 Z-.1 F4. # Drill at the position Z=-0.1 inches with a feed rate of 4 in/min N120 Y2. F8. # Apply a feed rate of 8 in/min in the Y 2in position N122 X1. # N124 G2 X2. Y1. R1. # Circular clockwise interpolation with a radius of 0.5 inch and end at position X=2 inch and Y=1 inch N126 G1 Y.5 # Drill at the end position (Y=0.5 inch) N128 G2 X1.5 Y0. R.5 # Circular clockwise interpolation with a radius of 0.5 inch and end at position X=1.5 inch and Y=0 N130 G1 X0. # Drill at position X=0 N132 G0 Z.25 # Rapid transverse at the point Z=0.25 inches N134 M5 # Spindle off M136 G91 G28 Z0 # Incremental programming N138 G28 X0. Y0. # Tool returns to the home position (0,0) N140 M30 # End of program % Last edited by BlackIbanez; 11-23-2005 at 12:05 PM. |
Note : Cincinnati Mills use H1 ...Hx as fixture offsets. The G1 lines are moving at the last F rate. - Not drilling. M136 G91 G28 Z0 (Returns Z axis to home position) |
