Results 1 to 11 of 11
Thread: 1/2 -14 NPT Internal Threadmilling
    Jan 2008
    Question 1/2 -14 NPT Internal Threadmilling
    Running an old M500/50 Mazak Horizontal.
    Looking for a threadmill program for a seco 14 TPI threadmill. Seco's calculator does not work for my Mazak.
    Prefer to use G3.1X,Y,Z I,J P, F programming.
    Hole dia is .719" tapered to .672" from pipe tap reamer.
    Can anyone help me?
    Jun 2010
    united states
    1_2 npt
    I mill that thread.
    What tool are you going to use?
    I bought a thread mill from thread mills USA part #TM NPT.
    With this mill you don't make a tapered hole the thread mill will do it for you.
    Also if you buy there threadmill they will make you a program in excel.
    Jan 2008
    I use a Seco R396.19 - 4003.0X14NPT insert threadmill.
    Jun 2010
    united states
    Do you have a CAD CAM?
    May 2004
    What do you mean, "Seco's calculator does not work for my Mazak."? It gives you the positions doesn't it? You just need to do a little extra calculation to convert it to the format you need. Post Seco's result here and I am sure someone can explain how to convert it.
    http://www.kirkcon.com/
    Jan 2008
    Here is the Mazatrol program for threadmilling a 1/2-14 NPT. Not sure why it won't work...
    N5G00G17G80G49G40;
    N15G91G30X0.Y0.Z0.;
    N25G0T20G90G94;
    N35M39M6G00;
    N45G0X0.Y0.;
    N55Z.1000G43H44;
    N65S3750M3;
    N75G1X0.F1.M8;
    N85G1Z-.6514F10.0;
    N86G1G41X-.3655Y0.I0J-1F6.2;
    N87G17G3.1X-.3674Y0.Z-.4371I.3655J0.P3F6.2;
    N88G40G1X0Y0;
    N89G1Z-.6514F10.0;
    N165G1G41X-.3815Y0.I0.J-1.F6.2;
    N175G17G3.1X-.3834Y0.Z-.4371I.3815J0.P3F6.2;
    N176G40G1X0Y0;
    N177G1Z-.6514F10.0;
    N182G1G41X-.3915Y0.I0.J-1.F6.2;
    N183G17G3.1X-.3934Y0.Z-.4371I.3915J0.P3F6.2;
    N185G40G1X0.Y0.;
    N186G1Z-.6514F10.0;
    N191G1G41X-.4025Y0.I0.J-1.F6.2;
    N192G17G3.1X-.4044Y0.Z-.4371I.4025J0.P3F6.2;
    N194G40G1X0.Y0.;
    N196G1Z-.6514F10.0;
    N197G1G41X-.4025Y0.I0.J-1.F6.2;
    N198G17G3.1X-.4044Y0.Z-.4371I.4025J0.P3F6.2;
    N203G40G1X0.Y0.D000;
    N204G0Z5.000;
    N210G49G91G30Z0.;
    N215G30X0.Y0.;
    N225G90;
    N235M09;
    N245M19;
    N255M99;
    May 2004
    Might have to add K value for arc centers. When going from Z-.6514 to Z-.4371 the center of the arc would be about 1/2 way between the two, making K0.1072.
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    'it won't work'..... ???
    A little more info might help. are you getting an error or alarm? if so what alarm or error?
    Jan 2008
    No error, no alarms, just bad threads. I'm thinking that the taper may be wrong..... Threads don't quite allow the thread gage to depth, and the fittings don't engage deep enough. Fairly new to thread milling, so I'm scratching my head on this one.
    Aug 2011
    Fordaville
    Jan 2008
    Fordav11.... Just downloaded the Vardex threadmilling wizard. Looks like it may work.... now to wait for the machine time to try it out. Thank you all for the help. I may have some hair left after pulling it out after all.
    Paul
    1. Newbie- threadmilling
      By brianp-jag in forum GibbsCAM
      Last Post: 10-11-2011, 04:12 PM
    2. Threadmilling
      By naytep in forum GibbsCAM
      Last Post: 11-21-2010, 04:03 PM
    3. Threadmilling with Fanuc 18i-TB
      By mroy0404 in forum Fanuc
      Last Post: 03-16-2010, 09:21 AM
    4. NPT Threadmilling
      By john_mccarron in forum GibbsCAM
      Last Post: 07-20-2007, 06:54 PM
    5. Threadmilling
      By MetalMolder in forum General Metalwork Discussion
      Last Post: 06-29-2007, 04:41 AM
