Results 1 to 6 of 6
Thread: Slot cutting ramp in and out Help
    Jan 2010
    I have a taig cnc mill and I am trying to cut some slots/splines and a round shaft. I have mach 3 with wizards it does the ramp in but no ramp out I would like to be able to ramp out at same angle as the ramp in to give a uniform look. Any help is greatly appreciated.
    Thanks again
    Jan 2009
    united states
    I've never used mach 3 so can't help you there but it's pretty easy to do it if you just write a program manually in g-code.
    Jan 2010
    Can you show me an example?
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    you don't give any sizes to show exactly what you're doing.
    it may be easier if you post some of your existing program and someone can modify it
    Jan 2010
    this is first few passes it ramps in and I need it to ramp out also
    G0 X0 Y0
    G1 Z0.0000 F30
    X0.1908 Y0 Z-0.01
    X3.5 Y0
    G0 Z0.1
    X0.1908 Y0
    G0 Z 0.04
    G1 Z-0.01
    X0 Y0
    X0.1908 Y0 Z-0.02
    X3.5 Y0
    G0 Z0.1
    X0.1908 Y0
    G0 Z 0.03
    G1 Z-0.02
    X0 Y0
    X0.1908 Y0 Z-0.03
    X3.5 Y0
    G0 Z0.1
    X0.1908 Y0
    G0 Z 0.02
    G1 Z-0.03
    X0 Y0
    Aug 2011
    Fordaville
    its pretty simple. just work out the difference between the start point in X and the ramp-in point in X and then add that to the X end point and feed up to the same Z point where you started.
    G0 X0 Y0
    G1 Z0.0000 F30
    X0.1908 Y0 Z-0.01
    X3.5 Y0
    X3.6908 Z0
    G0 Z0.1
    X0.1908 Y0
    G0 Z 0.04
    G1 Z-0.01
    X0 Y0
    X0.1908 Y0 Z-0.02
    X3.5 Y0
    X3.6908 Z-0.01
    G0 Z0.1
    X0.1908 Y0
    G0 Z 0.03
    G1 Z-0.02
    X0 Y0
    X0.1908 Y0 Z-0.03
    X3.5 Y0
    X3.6908 Z-0.02
    G0 Z0.1
    X0.1908 Y0
    G0 Z 0.02
    G1 Z-0.03
    X0 Y0
    I assume this is what you want? I can't tell if X3.6908 would over-cut into your part because I don't have sizes/drawing/better info.
    Maybe you want to ramp up to the X3.5 point? So in that case you would start ramping up before X3.5 like this....
    G1 Z0
    X0.1908 Z-0.01
    X3.3092 (3.5 - 0.1908)
    X3.5 Z0
    G0 Z0.1
    A few sizes or simple sketch would help and I could write you a complete working program.
    If I were doing a square slot using ramping I would do something like this....
    G0 X0 Y0
    Z0.1
    G1 Z0 F30
    X3.5 Z-0.05
    X0 Z-0.1
    X3.5 Z-0.15
    X0 Z-0.2
    X3.5 Z-0.25
    X0
    G0 Z0.1
  1. Need Help!- Cutting Slot With Ball Mill
    By PMF in forum BobCad-Cam
    Last Post: 10-13-2011, 06:15 PM
  2. Cutting a slot in a shaft
    By Mogzieno1 in forum Solidworks
    Last Post: 11-18-2008, 01:59 PM
  3. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-09-2008, 10:02 PM
  4. cutting a slot
    By adamchapman in forum Mastercam
    Last Post: 08-21-2008, 04:40 PM
  5. powermill and slot cutting with woodruff tool
    By krustykrab in forum General CAM Discussion
    Last Post: 02-23-2006, 05:25 AM
