Old 01-04-2012, 09:15 AM
wileydavis is on a distinguished road
Lathe Code for Mill With Subroutine
I'm trying to hand-code a program to do some turning on my RF-30 mill and I'm trying to wrap my head around subroutines. The program below is for a Mach3 controller and takes a Cut Depth and Cut Length parameter, then loops however many times from the start point.
I've never written a program by hand before, so I was wondering if any of you see any major flaws with this approach. Cheers, and thanks for any insight.
Code:
( Axle )
G20 G90 G91.1 G64 G40 G49
G0 Z0.25
T0 M6
G17
M3 S1900
G0 Z0
G1 F5 X.250
#1=.010 (SUBROUTINE DEPTH)
#2=1.27 (SUBROUTINE LENGTH)
M98 P100 L12
(FINISH PASS)
G1 F5 X.123
G1 F17 Z-1.270 X.125 (TAPER SPRING PASS)
G1 X.350
M5
M30
O100
(TURNING SUBROUTINE)
G91 (BEGIN INCREMENTAL)
G1 F5 X[0-#1] (CUT DEPTH)
G1 F17 Z[0-#2] (CUT LENGTH)
G1 X#1 (PULL OUT TO START X")
G0 Z#2 (RAPID TO START Z)
G1 F7 X[0-#1] (BACK TO START X)
G90 (END INCREMENTAL)
M99
Old 01-05-2012, 12:38 AM
fordav11's Avatar
fordav11 is on a distinguished road
What kind of machine is this? Normally you can't do 'real' XZ turning on a mill.
If you have never programmed long hand before why are you over-complicating it by using macro variables? It would be easier to just use long hand code. The sub with incremental values is ok but using macro just makes it harder to understand from the point of view of someone who has never written long hand code before.
As for problems, you are in G17 (XY plane) and you are cutting XZ plane (G18). It's not a problem here because you are only cutting straight but if you cut an arc with G02/G03 you will get an alarm (wrong plane)
Also T0 is not valid except when cancelling an offset. A T0 with M6 after it will generate an alarm.
Your program is very strange regardless of these errors
Old 01-05-2012, 08:11 AM
The machine is a round column mill/drill converted to CNC with servos and a Mach3 controller. I'm chucking up 1/2" dia aluminum stock in a collet and clamping some lathe tools in the vice.
I guess I figured I was simplifying things. The subroutine keeps me from making dangerous numerical typos, and the parts I'm making have a shoulder and three grooves of varying depths and widths, so I figured by passing in parameters I could use the same subroutine for each groove and the shoulder. It's not in the example I posted, but my plan was to call M98 multiple times, and correspondingly rewrite the parameters for each call. Is that a piss-poor way to go about it?
Yeah, my plan there was to switch to G18 only for any arc moves (none in this program) and then switch back to G17. Since it's a mill, I wanted to be sure it stays in G17 as a default in case the next program doesn't explicitly call G17.
Good point. My controller doesn't alarm with a T0, but I'll switch it to an unused tool number and use the tool offset for the stock length.
How you skin a cat can say a lot about your personality, I suppose
Old 01-05-2012, 12:55 PM
fordav11's Avatar
that's a novel approach. I guess if that's all you have to work with then it's fine if it works.
on a mill it's not necessary to use T0 to cancel offsets.
Tool length offset is called with G43 and cancelled with G49
Tool diameter offset is called with G41/G42 and cancelled with G40
T0 isn't required unless your control somehow acts like a lathe control.
I don't skin cats, I usually roast them on a spit. The skin usually just falls off with the cooked meat. Much easier than skinning it manually.
Old 01-08-2012, 09:49 PM
Success!
I finally got the subroutine working. Turned out I had the wrong line-ending on my text file encoding and Mach3 didn't like the line return after the M99. Once I saved to a windows line ending, it ran fine (similar to the above code but not the same program). Here's a video of the outcome (turning a shoulder, a 1/4" wide groove, and parting.
http://thungy-videos.s3.amazonaws.co...ng-960_540.mp4
Thanks for the advice on T0. Cheers.
Found in archives - A2100 thread mill subroutine Ron P Cincinnati CNC 2 05-17-2011 08:38 AM
subroutine kendo Okuma 3 01-14-2010 06:50 AM
Problem- macro code inside of a subroutine brockmo Fadal 7 03-12-2009 10:32 PM
Program g-code for mill as multiple tool lathe? Monte G-Code Programing 12 04-18-2008 11:18 PM
G-code viewer (subroutine) hao G-Code Programing 1 11-15-2006 06:10 AM
