| G-Code Programing Discuss G-code programing and problems here! |
I've been reading a comp problem thread, and while I have nothing to add to the thread (I could, but it's well covered), one thing continues to irk me just a little. It's the definition of G41 and G42. G41 has always meant "cutter to the left of the programmed geometry" and G42 to the right. The Climb / conventional definition may work 95% of the time, but all I have to do to switch from climb to conventional is change from a right hand cutter to a left hand cutter, no re-programming necessary. Just my $0.02 Beege |
| I agree, Climb/Conventional has nothing to do with G41/G42, except to add confusion.
#10
Right! I've worked with lathes where the X plus was toward the operator, and some where the X plus is away from the operator (slant bed especially). Since there is no formal Y axis, one has to figure out where Y positive is supposed to be, then program both TNRC and radius directions accordingly. |
#11
| And the water gets muddier and muddier with every post. It does however help me rationalize one of my methods. Method #1.....I don't use cutter comp. I am confused enough on most days so I spare myself the agony of adding insult to injury. Beege.....good thread. It is a great example of taking definitions with a grain of salt. Stevo |
| cutter comp in G91 | KEENANDOG1 | Haas Mills | 8 | 10-08-2011 02:40 PM |
| cutter comp | mdred68 | Tormach PCNC | 15 | 11-07-2010 01:40 PM |
| Cutter comp on an id hole< cutter diam.?? | PaintItBlue | Haas Mills | 5 | 05-05-2008 06:30 PM |
| cutter comp in eia | mrwright | Mazak, Mitsubishi, Mazatrol | 3 | 05-21-2007 07:53 AM |
| 18-it cutter comp | newcinhypro | Fanuc | 1 | 01-25-2006 08:00 PM |
