Results 1 to 2 of 2
Thread: GILDEMEISTER NEF400EPL
    Nov 2011
    egypt
    I have a problem with CNC Lathe Gildemeister NEF400 EPL, the G01 code doesn’t work, when the machine in a manual running mode G00 it works, but as soon as it moves to automatic mode G01 the spindle works but the cutting head doesn’t move (Z & X) stops totally, the machine operator did all the kind of program check everything looks fine, I’m attaching 2 pictures for the machine and the controller.
    Machinetype CNC Lathe
    Make GILDEMEISTER (Year 1983)
    Type NEF400 (No. 68094)
    167-30-0100 / 016
    Dec 2004
    U.K.
    Quote Originally Posted by nice-day View Post
    167-30-0100 / 016
    Have you programmed a feedrate for example... G95 F0.20 The machine will not feed if a feed has not been programmed. I have not worked this machine but i have worked on other guildemeister lathes and after the machines are powered down and back up , spindle speed and feed rates have to be initialized.
    Keith.
  1. Need Help!- Gildemeister NEF CT 40
    By gugu in forum Mini Lathe
    Last Post: 04-12-2013, 04:57 AM
  2. Need A Quote- Gildemeister CNC Lathe
    By ReallyBigDoors in forum Want To Buy...Need help!
    Last Post: 10-03-2011, 03:07 PM
  3. Need Help!- Help with Gildemeister/siemens
    By turner13 in forum General Metal Working Machines
    Last Post: 09-25-2011, 03:25 PM
  4. gildemeister lathe
    By roni21702 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 03-08-2010, 12:09 PM
  5. Need Help!- Gildemeister T-42
    By lonely in forum General Metal Working Machines
    Last Post: 10-26-2008, 08:57 PM
