Old 11-03-2011, 09:51 PM
Machining is on a distinguished road
Combining three posted programs into one
I want to combine three posted files (NC files) into one and then change the offsets in two of them to G55 & G56. I'm not good at code. What do I need to watch out for?
Old 11-04-2011, 01:50 AM
angelw is on a distinguished road
If the three programs were all stand alone and proven, the main thing you have to be mindful of, and you have already made reference to it, is that the correct Work Shifts are being used for all three programs, whether they are being used on 2nd and 3rd operations of the one part, or on three different components.
When programs are created as stand alone programs, they often have a particular character set at the beginning. Fanuc have the “O” character, plus a program number, Okuma can have “MIN”, and so on. If your control uses such characters, you need to remove these from the head of the two programs being appended to the first. Failing to doe this with a Fanuc control will result in the combined programs being split back into the original three by the control when the program is uploaded. Also, the M30 or M02, along with any control characters, such as "%", need to be deleted from the 1st and 2nd programs.
It’s also usual for a safety line to appear at the head of a stand alone program, such as:
N1 G00 G17 G21 G40 G49 G80
When the two other programs are appended to the first, the above line appearing at the head of these two programs will be superfluous, but will not affect the running of the programs in any way. Accordingly, it is quite optional whether these extra blocks are deleted or not.
Regards,
Bill
Old 11-04-2011, 11:37 PM
sinha_nsit is on a distinguished road
This is how you can insert a program into another program:
An existing program (say, program number 2345) can be inserted
at an arbitrary position in the current program (say, program
number 1234). These are the steps:
• Select the EDIT mode on the MOP panel.
• Press the PROG key on the MDI panel.
• Type O1234 (or simply 1234) and press the O SRH soft key.
• Press the soft key OPRT. If OPRT does not appear, press the
return-menu soft key (< ).
• Press the next-menu soft key ( >).
• Press the soft key EX-EDT, followed by MERGE.
• Move the cursor to the word, before which program number
2345 is to be inserted, and press the soft key ~’CRSL or
~BTTM’ (in the latter case, the insertion is done at the end
of the current program, regardless of the position of the
cursor).
• Type 2345 and press INPUT on the MDI panel.
• Press the soft key EXEC.
After this operation, program number 2345 is inserted at
the desired location in program number 1234, creating a
modified program number 1234. Program number 2345 remains
unaffected.
Combining grounds logic and HV simpson36 General Electronics Discussion 5 05-18-2010 10:42 AM
2 or more CO2 Laser beams combining? Konstantin Laser Engraving & Cutting Machines 9 02-21-2009 12:08 PM
Need Help!- Combining DXF in A9CAD blue_steel OpenSource Software 6 01-29-2009 06:38 PM
CNC Posted Programs corster CNCzone Club House 0 02-15-2007 08:20 AM
Combining woodworking with CNC Patrick2by4 WoodWorking 47 10-29-2006 06:44 PM
