Old 10-23-2011, 12:19 PM
lyassa is on a distinguished road
G-Code to carve out an area
Is there any G code command or routine such that I supply it the xy coordinates of 3 or more points, and it carve out the area enclosed by these points? If no such G code command, how do I go about that? Your answer is very much appreciated.
Old 10-23-2011, 01:30 PM
As far as I know there is no general G command to do what you want. Some machines have canned cycles for simple pockets. Haas is one where you drill a hole at the center of the pocket and just program the perimeter coordinates once and then the machine starts at the center and works its way out.
Or of course you can use a CAM program.
Failing all these you need to code it yourself which is possible but can get tedious.
Old 10-23-2011, 03:13 PM
Thanks Geof. It seems that I will end up using excel to generate the gcode to do the area fill (or rather empty). I am able to do it with shapes like squares and rectangles. I will try to do the calcs on irregular shapes.
It is hard to believe that nothing is available out there!
Old 10-23-2011, 06:19 PM
texaspyro is on a distinguished road
Without knowing which CNC control that you are using, it is impossible to answer your question.
Several controls do have some generalized pocketing commands... they do tend to be a royal pain to get working since they are seldom documented properly and they have tons of parameters.
Old 10-24-2011, 09:31 AM
ProProcess is on a distinguished road
Originally Posted by texaspyro View Post
...Several controls do have some generalized pocketing commands... they do tend to be a royal pain to get working since they are seldom documented properly and they have tons of parameters.
This is where a good understanding of a give machine's macro language proves invaluable.
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
Tags
g-code command area
Need Help!- v-carve Claude Boudreau BobCad-Cam 4 03-30-2010 09:13 AM
Problem- v-carve in mm serocco Vectric 5 02-13-2008 05:13 AM
V Carve tangocc35 Joes CNC Model 2006 4 10-17-2007 03:18 PM
how to mill inside an area and not over an area? jedioliver Visual Mill 10 02-21-2007 11:52 PM
V Carve possible changes Brian P Vectric 2 09-11-2006 03:32 PM
