Old 08-28-2011, 02:02 AM
abrohit is on a distinguished road
Trouble while inserting commands
I am using FANUCT OiT. I want to add coments in programme for which "(" ")" is required . But iam not able to find the ( ) in keypad. Please tell how to type ( in programme.
Old 08-30-2011, 02:55 AM
sinha_nsit is on a distinguished road
A parameter slects between ( and [ for the same key.
Can you type [ ?
Old 08-30-2011, 06:48 AM
dcoupar's Avatar
Parameter 3204 (see attached).
Name:	0i Parameter 3204.jpg‎
Old 09-02-2011, 09:46 AM
chucker's Avatar
chucker is on a distinguished road
PARENTHESES / BRACKETS
I have a machine the same way and I made 2 programs and call them up with a M code in MDI when I want to switch it saves a lot of key strokes.
O9028 (PARENTHESES M64)
G10L50
N3204R00000101
G11
M30
O9029 (BRACKETS M65)
G10L50
N3204R00000100
G11
M30
Last edited by chucker; 09-02-2011 at 12:43 PM. Reason: type 2nd program name was wrong
Old 09-02-2011, 10:58 AM
ProProcess is on a distinguished road
G10L50
N3204R00000101
G11
M30
O9028 (BRACKETS M65)
G10L50
N3204R00000100
G11
M30
Nicely done!
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
Old 09-03-2011, 01:48 AM
If both are needed at the same time, C-EXT softkey can be used.
Old 09-08-2011, 07:37 AM
chucker's Avatar
C-EXT thanks sinha I guess I just never looked at this key
Tags
adding coments, cnc programming
Need Help!- inserting custom code beartrax Mastercam 3 08-29-2008 10:53 AM
Stop inserting M3 Big John T SheetCam 1 05-11-2008 03:35 PM
Inserting Links besc Forum Questions or Problems 8 05-29-2007 06:15 AM
TCC v3 - keeps inserting G28 - why phil burman TurboCAD/CAM 1 06-25-2006 11:29 PM
Inserting an excell spreadsheet smoa1980 Mastercam 10 05-13-2006 11:11 PM
