Old 08-11-2011, 11:41 PM
winaa is on a distinguished road
tricordial milling
hi I need to mill a slot with a long cutter that is prone to vibration. I need to use this tool due to the depth of the slot. Its a very basic slot that 158mm long 32mm wide.
Can anyone help me with the code for this?
I have access to both mastercam X2 and Bobcad24 I have tried using these for the slot but they both just ramp down to the cutting depth then machine the slot by sidemill, I know this will cause vibration.
Basically it would be a series of interlocking circles with a radius of half the slot width to the correct length.
thanks.
Old 08-15-2011, 03:50 PM
OptionCNC is on a distinguished road
re
How deep is the slot?
What kind of material?
I'd drill it out with a 3/4 first, pop some holes in the slot first to get the majority of it out then go in with a 3/4" em and rough it out...
Shouldn't NEED to use Tri-milling for something like that. Tri milling works best for larger pockets. expecially with a MINICUT endmill...
Old 08-17-2011, 07:02 PM
Kiwi is on a distinguished road
I'm not familiar with tricordial milling as I don't have a cam program with that feature.
Is this the sort of path you require?
The path shown is for a 10mm cutter.
Old 08-18-2011, 03:39 AM
Yeah thats the sort of path I was looking for. I thought there would be some way of coding it without cam software being just a straight slot. I got close the other day but while i got the spiral to move in the X axis the radius increased as well.
I actually generated a tool path in Bobcad 23 but at over 4000 lines for 1 simple slot I thought Ill try something else.
As OptionCNC stated plunge milling or drilling a series of holes might be a good alternative.
Is that bobcad version21 in your pic?
Did you draw the tool path by hand?
I tried to make a contour but couldn't get that to work.
Old 08-18-2011, 04:09 AM
Originally Posted by winaa View Post
...Did you draw the tool path by hand?.....
No, I've written a VBasic program to generate the code which I pasted into BCC ver21.
If you can supply the start and end centres co-ords of the slot with the tool diameter and tool step-over I can supply you some code.
Another way would be to do a loop, step along in G91 (increment) and repeat.
Free MastercamX setup sheets for milling free 3 axis milling active designer setup sh bigban Mastercam 1 07-26-2011 05:28 AM
Retrofit my Old Milling (Milling No. 0) mistry_hemant General CNC (Mill and Lathe) Control Software (NC) 0 01-17-2011 04:08 AM
CNC Milling Machine Packages and Bespoke CNC Milling Machines worldofcnc Product Announcements & Manufacturer News 0 05-27-2010 08:20 AM
Offset Chain Milling vs Path Milling ynnek TurboCAD/CAM 1 03-11-2009 05:29 PM
Milling with bottom vs milling with side? REVCAM_Bob CNCzone Club House 13 06-30-2008 09:23 AM
