Old 08-08-2011, 10:54 PM
Jie Jie is offline
Jie is on a distinguished road
Programming for Mach2 CNC Control Application
Sorry for disturbing~ Is there any codes for Mach2 or Mach3 programming(for 3axis) which when I stop moving X and Y axis and Z-axis for few seconds..it will like triggering..then Z axis will be moved upwards? Thanks =)
Old 08-11-2011, 11:20 PM
dpuch is on a distinguished road
Short answer is no. But I do not think you explained what you really wanted and why you want it.
If in a program, why not just program the Z move.
If when jogging manually, no.
Old 09-20-2011, 03:24 AM
imbalanced_MJR is on a distinguished road
Is this correct program for Mach3?
Friend asked me to write him some drilling program for some small homemade CNC drill running on Mach3. Spindle an coolant are not controlled over CNC controller. Just X Y an Z.
Can u tell me is this going to work or/and what changes should I make. Is that subprogram correct?
15i control help for (AiCC) (hpcc) high precision contour control programming gibbsmaster Fanuc 2 12-28-2007 09:57 AM
No XYZ cursor key control on Mach2 alnicov Mach Software (ArtSoft software) 12 03-07-2006 11:16 AM
newer mach2 version, no spindle control now?? yukonho Mach Software (ArtSoft software) 4 05-08-2005 01:47 PM
Can Mach2 control my phase inverter MrBean Mach Software (ArtSoft software) 3 10-12-2004 07:20 PM
Mach2 remote control steveald Mach Software (ArtSoft software) 1 01-19-2004 08:20 AM
