09-21-2005, 06:55 PM
Would it be possible to just use a couple different drill cycles with lower pecks as you get deeper?
Sorry I can't help directly with the question.
The only deep hold drilling I've ever done, was with a G81 (no peck). Hole was approx. 23" deep, 3" diameter. Inserted 'drill head' on a hollow body, with collant applied directly to the head(through the body), and chips/coolant flowed back through the hollow body - think tube inside a tube(one for coolant to, and one for coolant/chips from). Luckily, the machine used TCM (torque controlled machining). So it adjusted feed/speed as needed based on torque being used. It would even fault out if it senced the inserts break, or if it went over a certain torque value. This was done on a Cincinnati Horizontal mill.
__________________ Dustin B.
I hear and I forget.
I see and I remember.
I do and I understand. |
