Old 08-02-2011, 09:18 AM
gogego is on a distinguished road
Need an assist on chamfers...
I keep getting Alarm 55 (Missing move value in CHF/CNR)
move distance is commanded less than the corner radius part..
here is the section Im stuck on now
#15=.03
G96S300M4
Z.2
G0X[#100+.1]Z.1
G71U[#1](DOC)
G71P420Q430U.04W.005F.01
N420 G0X[#119-[2*#15+.03]] Z.01
G1X[#119]C-[#15]
Z-[#127]F.007
X[#120]C-[#16]
Z-[#127+#128]
#2=#120
The prog. reads N420 then alarms out
Initially I didn't have the +.03
I have tried +.1 but still get alarm
any advice/help would be appreciated
I'm just a butcher masquerading as a machinist
Old 08-02-2011, 11:39 AM
ProProcess is on a distinguished road
Make sure that you're in the correct plane (G18 I assume).
After that, the move after the chamfer needs to be atleast as big as the chamfer itself and in the same direction.
Too, are you sure that you need the "-" with the C value.
Though I do not know what control you're using but base on your code, something like this...
Code:
G1 Z0
X.5 C.03
Z-.05(THIS MOVE NEEDS TO BE AT LEAST AS BIG AS THE C VALUE)
X1.
HTH
Good luck
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
Old 08-06-2011, 01:39 AM
sinha_nsit is on a distinguished road
Possibly your control does not allow C within G71.
Need Help!- Can someone make a excel spreadsheet for OD Chamfers SWISS20 G-Code Programing 4 07-12-2011 02:53 PM
Newbie- Mastermcam x4 and chamfers musicmaneman1 Mastercam 2 06-14-2011 07:22 AM
Cutting chamfers and fillets? prestondocks Mastercam 7 05-06-2011 01:06 PM
Need Help!- Naked Edges on Fillets and Chamfers in Rhino spincaster Rhino 3D 12 04-05-2010 05:05 AM
air assist geekinesis Laser Engraving & Cutting Machines 1 11-10-2009 11:48 AM
