Old 07-25-2011, 12:37 PM
Gashmore is on a distinguished road
Timing M7/M9 on/off?
Unusual situation. I have a piece with 1000+ 1/8" holes that need to be filled with colored epoxy. (Double 12 Domino set) I have an automatic dispenser that drives a syringe that I plan to mount on the Z axis next to the spindle. I figure I can use one of the unused outputs (like M7/M9) to control the dispenser.
My problem is the on/off cycle to fill the hole is only about 200-250ms. How can I accurately control the timing? (Running Mach3)
Will this work?
F30 (Set feed rate to .10" in .20 Seconds)
G0 Xxx Yyy Z.1 (Locate hole)
G0 Z-.10 (Lower the needle into the hole)
M7 (Start epoxy flow)
G1 Z.010 (Retract needle)
M9 (Turn off flow)
Z.10 (Retract to clear part)
Old 07-25-2011, 02:36 PM
chucker's Avatar
chucker is on a distinguished road
M7 M9
why not just rapid to the hole then into the hole then M7 dwell(G04) then rapid up and over to next hole and repeat
Old 07-25-2011, 03:08 PM
That would probably work better. Just that I have been filling all those D#$%ed holes by hand and if I don't put the injector needle dead center down in the hole the epoxy bridges over and leaves a bubble. OTOH, the machine has a lot steadier hand than I do.
L Timing pulley hob? DennisCNC General Metalwork Discussion 2 08-30-2009 03:45 PM
Need Help!- Timing pulleys native34 Bridgeport and Hardinge Mills 3 08-28-2009 07:18 PM
Timing Belts kingpav Linear and Rotary Motion 1 09-28-2008 09:54 PM
THC Timing? Red Earth CNC Plasma and Waterjet Machines 27 04-16-2007 10:03 AM
Timing belts CAM_MAN DIY-CNC Router Table Machines 11 04-13-2006 12:24 PM
