| G-Code Programing Discuss G-code programing and problems here! |
Hello, I am having a problem with this section of Code and thought I would ask for help setting feedrate to 0.5 on this one line. I have tried many different things but no help. Any suggestions would be welcome. Thanks in advance. N038 G00 X000.750 Y002.000 N039 G01 Z001.1 N040 G01 X002.000 Y000.750 F.5 (This is where I need feed rate set to 0.5) N041 G01 X000.750 Y002.000 N042 G00 Z000.000 |
Hello, Thank you in advance. Here is the g-code file. The machine is a cnc router made by Thom Carr CNC. Basically I am first cutting 4 pointlists then going back to the pointlists and cuting 4 45 degree slots. On the 4 slots I need to slow the feed rate down to a crawl. I use Kcam for the controller. N001 [KCAM CONVERSION] N002 [ORIGINAL FILE: BALLNOSESLOTCUTTERFIRST.DXF] N003 % N004 G90 N005 M03 N006 G00 Z000.000 ( point list begin ) N007 G00 X002.000 Y009.250 N008 G01 Z001.1 N009 G01 X002.000 Y009.250 Z000.000 N010 G00 Z000.000 N011 G00 X008.000 Y009.250 N012 G01 Z001.1 N013 G01 X008.000 Y009.250 Z000.000 N014 G00 Z000.000 N015 G00 X009.250 Y002.000 N016 G01 Z001.1 N017 G01 X009.250 Y002.000 Z000.000 N018 G00 Z000.000 N019 G00 X000.750 Y002.000 N020 G01 Z001.1 Pointlist end N021 G01 X000.750 Y002.000 Z000.000 N022 G00 Z000.000 N023 G00 X002.000 Y009.250 N024 G01 Z001.1 0 Begin 4 angle cuts need slow speed here N025 G01 X000.750 Y008.000 N026 G01 X002.000 Y009.250 N027 G00 Z000.000 N028 G00 X008.000 Y009.250 N029 G01 Z001.1 N030 G01 X009.250 Y008.000 N031 G01 X008.000 Y009.250 N032 G00 Z000.000 N033 G00 X009.250 Y002.000 N034 G01 Z0001.1 N035 G01 X008.000 Y000.750 N036 G01 X009.250 Y002.000 N037 G00 Z000.000 N038 G00 X000.750 Y002.000 N039 G01 Z001.1 N040 G01 X002.000 Y000.750 N041 G01 X000.750 Y002.000 N042 G00 Z000.000 N043 M05 N044 M30 end. |
I was going to do 2 programs one with a low feed rate to cut the angles then another program to complete the project but I would like to learn how to set feed rates in a g-code program. More of a wondering how to rather than a need too as I can get around it but it would be nice to be able to program feed rates into a g-code program when needed. Thanks for the idea. |
| I don't know the answer to your problem sorry. All the machines i've used would cut at F.5 or sometimes F0.5 depending on machine. Will the machine feed that slow? I'm really wondering why all the extra zeros in your code. Whynot X0.0 or even X0.0000. Do you write the code on the machine? The X000.005 would have me seriously confused.Lol. Good luck with your problem. Judleroy |
| Hey, that stuff gives me a headache. Waaaay too many 0s. Don't know anything about the Kcam you are using. I'd expect it should hopefully handle .5 ipm, but cannot say. I did not see any other specified feedrate in there. But, I'd have it more like this: N001 ............ N012G1Z1.1 N013G1X8Y9.25Z0 N014G0Z0 N015G0X9.25Y2 N016G1Z1.1 N017G1X9.25Y2.Z0 N018G0Z0 .......... Actually I seldom number the blocks unless I might need them for restart points or branching. However, your Kcam may not accept code like that.... it could well be quite different than what I've used But setting feedrate should well be done in the line where you are starting that feedrate, in the form of F.5 or F0.5 and should remain until changed. It can also be placed in its own seperate line before the movement. This is in the case of metal working machinery that I have used |
| You misunderstand me I believe you are unable to set your feeds that low because your ramp values are above it. Therefore if you set your ramp values below it you will be able to set low feed rates and this issue will be solved. The ramp start values are part of your kcam config I believe.
| Oh!! DUH I see what you are saying now. That makes sense as I tried to set the feedrate both above and on the same line as the code which had no effect what soever..... (SMILE) I'll bet you are right about setting the ramp rate lower than the feedrate. Thank you so much..... I can't wait to get home and try it.. Thanks one and all I'll give it a try later this week and see if that helps....
#10
| Hello, I didn't write the code but rather had the controller convert a dxf file to g-code. I can set the number of decimal places in the program and I guess I have grown used to this format. (SMILE) Although it isn't necessary. The machine will cut really slow it was cutting at .001 ipm although the only way to tell it was cutting was to watch the readout. Its kind of fun experimenting with stuff like this. Thanks...
#12
Thanks for the insight. Its neat to see the way other folks do their code. I took out the F0 commands but I think setting the correct the ramp rate will solve the problem. The machine will cut verrrrrrrrrrrryyyyyyyyyy slow ( I discovered how slow the other day). :-) Kcam is a good controller for what I do. Thanks for the info on how to set the feedrate ...
| 4th Axis Feed Rate Problem | dkaustin | SprutCAM | 10 | 06-17-2011 12:52 PM |
| Problem- Feed rate problem | Rene Nuñez Paz | Hobbycnc (Products) | 4 | 03-08-2009 07:50 PM |
| Mach3 with Taig Motor Feed Rate Problem | alt255 | Taig Mills & Lathes | 8 | 12-13-2006 01:50 PM |
| Feed Rate Overide problem | Moondog | Machines running Mach Software | 0 | 06-14-2006 05:35 AM |
