It's not as simple as change the Z BEFORE running the code; I simplified the example to try to give a clear picture.
However, I need to change the Z INSIDE the code. Here's why.
The "wall" is between two areas that should align. I'm not really keen to recut the entire first section (which your suggestion would accomplish) because it'll take hours and because I don't think my machine will be able to hold accuracy over the whole area again.
Rather, what I'm anxious to try to smooth out the discontinuity over a span of rows:
- to back off say 20 rows from the discontinuity
- and remachine only that set of rows
- while lowering the cutting depth 1/20th of the discontinuity before each pass
