Old 07-06-2011, 08:56 PM
SWISS20 is on a distinguished road
Can someone make a excel spreadsheet for OD Chamfers
I can do minor programming editing, but really have a hard time with od 45deg. chamfers, sometime we are .100 infront of the part when we put them on and sometimes we are on the face.
Can someone create an excel file that I can type in my x and z locations and chamfer size and it will give me my x and z's.
Example
od of dim. = .500
size of chamfer = .025
z location before chamfer .100
=X
or something close to this thank you for any help and or advice you may have for me, i also will be using cutter comp.
Old 07-06-2011, 11:50 PM
broby's Avatar
broby is on a distinguished road
I guess every one has to learn some time or other, but you are kidding aren't you?
45° tapers are the easiest ones to calculate out.
The distance you move on Z is the same for X (on radius).
so... if your diameter is 0.500" and your size of chamfer is 0.025" and you are starting 0.100" away from the face your X point would be 0.100" in front of your Z face and your X value would be calculated from 0.500-(2x0.025)-(2x0.100) = 0.250"
Do you know how to use Trigonometry at all? as in Sin Cos and Tan?
Hope you can follow this... once you understand how to calculate the points, machining chamfers other than 45° becomes rather straight forward.
Regards
Brian.
Old 07-08-2011, 01:51 PM
TURNER is on a distinguished road
Regards
Brian.
BIG LOL
I asked my 12 year old kid, and got the answer with no calculator in 3 seconds. Do you want to subcontract for pocket money lol.
Old 07-08-2011, 07:10 PM
CNCRim's Avatar
LOL calculate 45 deg? it's same distant adject side.
Old 07-12-2011, 02:53 PM
stevo1 is on a distinguished road
Sorry Swiss20 but you have to expect a bit of ballbusting with that question. I am a firm believer in there are no bad questions but you’re walking the line.
Roll with the punches my friend. If you stay here long enough you can find a way to poke just about everyone here.
I guess my question to you would be “what are you having a hard time with on doing OD chamfers?”
Stevo
Newbie- Mastermcam x4 and chamfers musicmaneman1 Mastercam 2 06-14-2011 07:22 AM
Cutting chamfers and fillets? prestondocks Mastercam 7 05-06-2011 01:06 PM
Need Help!- Any Excel/VBA Experts out there to help me with an Excel G-Code Macro? HankMcSpank G-Code Programing 3 02-18-2010 07:58 AM
Make setup sheets directly from your CNC programs and print them in Excel ZedB General CNC (Mill and Lathe) Control Software (NC) 7 04-08-2009 05:21 PM
Metric Change Gear Combinations by J.W. Early Excel Spreadsheet CNCadmin Machine Problems, Solutions , Wireless DNC, serial port 0 05-26-2003 03:17 PM
