Old 07-05-2011, 01:00 AM
Rich L is on a distinguished road
G71 internal profiling question
I'm pretty new to G-code programming and I have a question about G71 internal profiling using a gang tool lathe. My control is Fanuc 0i Mate TB.
All of the descriptions I've seen show a left hand profiling tool doing its internal cutting against positive X inside (+X away from me) surface. My question is whether it is possible to use a right hand profiler against the -X internal surface. Does G71 care about the profile being on the negative side of center?
Thanks for any advice!
Cheers,
Rich
Old 07-05-2011, 07:37 AM
ad64075 is on a distinguished road
You can indeed profile on the X- side during a G71 cycle. I have done it many times. Just be certain your machine will allow enough travel in the X- direction.
Old 07-06-2011, 06:49 AM
sinha_nsit is on a distinguished road
In fact, X- internal machining is logically equivalent to X+ external machining as regards toolpath definition, start position of the tool and finishing allowances.
But on most machines, you may get an overtravel alarm.
Old 07-15-2011, 07:25 PM
Thanks for the indications it should work. Admittedly, I haven't quite tried it yet but I do wonder about the two consecutive warnings I've gotten here about overtravel. If the profile causes the toolplate (gang tool lathe) to move within bounds why would I see an overtravel alarm? Why would "most machines" give me an overtravel alarm for G71 internal profiling?
Cheers,
Rich
Old 07-16-2011, 08:47 AM
dcoupar's Avatar
On turret style machines you can only take the centerline of the boring bar holder a certain distance past the centerline of the spindle, so if you are boring on the x- side you may reach that limit (see attached .jpg).
With a gang-style machine, you should be able to arrange your tooling so the boring bar will run without x-axis exceeding the travel limits.
Name:	BB Overtravel.jpg‎
Need Help!- Profiling Question hkenuam BobCad-Cam 3 01-03-2011 12:28 PM
Profiling EPP richbads CNC Tooling 0 02-02-2010 01:54 PM
Need Help!- profiling chaz6966 BobCad-Cam 1 02-21-2009 06:15 PM
Profiling question in Pro-Nc jeffroot PTC Pro/Manufacture 6 04-01-2008 06:15 AM
Profiling Question Skeeterd5150 General Metalwork Discussion 3 07-15-2007 03:32 PM
