Old 07-04-2011, 07:14 AM
scorpionkeit is on a distinguished road
G76 cycle for BSPT
Can anyone give me G76 2 line info for a 1 inch BSPT 16.8 Standard length
thanks
Old 07-04-2011, 08:40 AM
g-codeguy is on a distinguished road
Internal or external? Code will be the same format as for any thread. All you need to know is the OD (or ID) and root diameters.
EDIT: Are you saying you don't know the correct format?
Old 07-04-2011, 09:23 AM
External thread. Am fine with parallel thread just unsure of turned diameters and thread info for this thread.
Old 07-05-2011, 09:37 AM
I've only made 3/4 and 1/2 inch Internal BSPP threads.
From Maryland Metrics Thread Data Charts for 1-11 BSPP/BSPF Class B:
Major Dia. 33.249/32.889 (1.3090/1.2948)
Pitch Dia. 31.770/31.410 (1.2508/1.2366)
Minor Dia 30.291 (1.1926)
That should do it for you.
Old 07-06-2011, 06:53 AM
sinha_nsit is on a distinguished road
For info about G76 in general, look at
Thread using g76 - Practical Machinist - Largest Manufacturing Technology Forum on the Web
Thread taper is same for both BSPT and NPT. So, R in the second block of G76 would be same.
Old 07-06-2011, 09:42 PM
Oops. How did I see BSPP instead of BSPT? Sorry about that. I'll try to pay better attention next time.
Heidenhain iTNC 530: Using Cycle 19 and Cycle 8 Dan B General CNC (Mill and Lathe) Control Software (NC) 4 08-27-2011 11:32 AM
Help on BSPT!! denfc Mechanical Calculations/Engineering Design 5 02-04-2009 01:10 AM
G76 CYCLE BAD DOG General Metal Working Machines 2 09-20-2008 04:33 PM
need some help guys with Bspt thread peaceandcalm General CNC (Mill and Lathe) Control Software (NC) 6 11-29-2007 08:21 PM
Threading 2" -11 BSPT nitemare Daewoo/Doosan 7 07-18-2006 03:47 PM
