| G-Code Programing Discuss G-code programing and problems here! |
Hi, I have been tearing what remains of my hair out trying to figure out how to code my CNC machine (which runs Mach 3) to produce radial slots 2mm deep at 36 degree intervals in a disk 9mm in diameter. I am sure there is a way to do this but for the life of me I can't figure it out. The disks are made from 18 carat gold so I can't afford too many mistakes :-) Any suggestions would be much appreciated Regards Richard |
| I'm not familiar with that control, how is your knowledge of Trig? You just need to interpolate along a 10° line. Another way would be if the control has a Bolt Hole Circle Helper, you could do 2 bolt hole patterns. One for the starting (close to center) location and one for the ending (away from center) location and interplolate between them. HTH. Good luck
__________________ Control the process, not the product! Machining is more science than art, master the science and the artistry will be evident. |
1, X coordinate = Cos(angle) x disk radius 2. Y coordinate = Sin(angle) x disk radius 3. The angle used in the calculation for each successive slot end point is simply increased by 36degs, ie 0, 36, 72, 108 etc. The sign (+ or -) of the coordinate will also result from the calculation. 4. If the slots go to the center, then 5 diagonal slots can be cut using two opposing end point coordinates as the start and end point of the slot being cut. 5. Use a radius in the calculation that will allow the cut to finish off of the disk if the slots are to go to the circumference of the disk. Regards, Bill Last edited by angelw; 06-22-2011 at 06:10 PM. |
| Richard, I had a similar but more complex program that I made in the past for an Okuma VMC. My disc was 10 inches in dia and .250 thick. I needed to machine 4 sets of .390 long x .062 wide slots through the plate. I used a Center drill & drill to drill out the inner and outer points of the slots then milled them with the program code below. The end mill had a .025 depth of cut which meant it did 10 passes per slot x 90 total slots. The local variables were: SA= start angle CV= # of slots BI= inner point BO= outer point AI= angle index If I needed to restart where I left off I turned on block ship and then started the program on line N91. I hope this example program helps you. --------------------- Partial Pgm below ------------------------------- N91(T91 .062 1/16 4F CARB E.M.) T81M6 M1 /3M8 G0X0Y0Z1S6000M3 NN1 CALL OSLOT SA=30 CV=6 BI=.0905 BO=.4805 AI=60 NN2 CALL OSLOT SA=15 CV=12 BI=.471 BO=.861 AI=30 NN3 CALL OSLOT SA=7.5 CV=24 BI=.9035 BO=1.2935 AI=15 NN4 CALL OSLOT SA=0 CV=48 BI=1.4435 BO=1.8335 AI=7.5 Y20Z20 M2 OSLOT /VC1=1 VC2=CV VC5=.05 NQ0 IF[VC1 GT VC2]NQ9 VC6=[SA-AI]+[VC1*AI] VC3=BI*COS[VC6] VC13=BO*COS[VC6] VC4=BI*SIN[VC6] VC14=BO*SIN[VC6] G0X=VC3Y=VC4 Z.05 NQ1 G1Z-VC5F.002 X=VC13Y=VC14 VC5=VC5+.025 Z-VC5 X=VC3Y=VC4 VC5=VC5+.025 IF[VC5 GT .25]NQ8 GOTO NQ1 NQ8 Z0 F.02 VC5=.025 G0Z.05 VC1=VC1+1 GOTO NQ0 NQ9 G0Z1M9 RTS EDITS AS OF 07/01/97 |
| Or lust program in polar coordinates CNC Mach3 G-Codes |
| write gcode for circle with 4 small circle inside it | Farzaneh_2010 | G-Code Programing | 3 | 12-13-2010 10:24 AM |
| Ramping into slots | traceflair | Haas Mills | 4 | 09-24-2010 02:59 PM |
| radial 5 cilynder | tonycorse | I.C. Engines | 55 | 04-18-2010 02:06 AM |
| Need Help!- Radial Groove | skmetal7 | PTC Pro/Manufacture | 38 | 04-04-2010 08:01 AM |
| T slots in MDF?? | JerryFlyGuy | DIY-CNC Router Table Machines | 26 | 03-10-2007 10:30 PM |
