Old 06-15-2011, 02:20 AM
Web Goblin is on a distinguished road
Z axis drive
HI all,
I am not new to cnc but I am a newbie to G code programming. All of my previous experience is in ESSI.
Here is my problem. I have just finished building my cnc router and have started setting it up. I am using USBCNC to control it. My Z axis is driven by an ACME thread and my initial pitch measurement is wrong so I am looking to measure the actual linear movement of the Z axis for 1 complete turn of the motor.
So can I program the controller to rotate only the Z axis stepper motor for 1 complete turn only so that I can measure the linear distance travelled with a DTI?
Regards
Ian
Old 06-15-2011, 10:50 AM
ger21's Avatar
Set up your steps/mm to 200times any microstepping amount (8x for 1/8, 10x for 1/10, ....), then tell the machine to move 1mm.
Old 06-16-2011, 12:08 AM
Thanks for the info.
I ended up altering the step count a bit at a time and measuring the travel distance on my DTI. I think I have it to within 0.1mm over 25mm now. I just need to sort out my travel limits now and get the machine running faster.
Regards
Ian
Need Help!- MR-S3 3 axis drive zsbojtos Mazak, Mitsubishi, Mazatrol 8 07-11-2011 06:39 PM
Need Help!- Fanuc 10tf, Axis Torque Alarm, mem Z axis Alarm, already changed Z drive and motor? blakemachine Fanuc 1 11-11-2010 12:42 PM
Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. kreutz Stepper Motors and Drives 3 07-03-2008 06:57 PM
C Axis Drive Enteralterego Fanuc 0 11-09-2006 03:54 AM
Axis Drive Fault Bluey Machine Problems, Solutions , Wireless DNC, serial port 3 11-03-2004 06:54 PM
