Old 06-10-2011, 11:59 PM
notselrach is on a distinguished road
G Code Question
Is there a Gcode command/s that will allow me to switch the X with the Y Axis? I am using Mach3 and can do it in "configurations". "Ports and Pins", but I'd like to leave that alone and change it at the program level. I am working with wood and sometimes it's best to rough cut against the grain. Not always enough space on the work piece to re-orient it............BC
Old 06-24-2011, 05:33 PM
ger21's Avatar
You can use G68 to rotate the part 90°.
Newbie- G Code question grttt3 BobCad-Cam 1 05-02-2011 04:38 PM
G code question Toolz_86 General CNC (Mill and Lathe) Control Software (NC) 2 09-28-2010 03:31 AM
G91 G code question beekeep G-Code Programing 8 07-13-2010 10:14 PM
G Code Question dgoddard G-Code Programing 3 01-02-2008 04:50 PM
M-Code question Chris64 General Metalwork Discussion 3 10-05-2006 07:07 PM
