Never seen it on ISCAR, & never suggested by their reps
The usage would be the same, no matter who supplied the application
just cut & paste into the NC program
Hello Superman!
Do you know, does iscar have that program?
Greetings from Robert.
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
lol
That said I generally prefer climb cutting. There are reasons to conventional cut and/or single point from the top of the hole, but that would not be my general practice.
Thread milling really isn't that complex. In fact it is almost identical to milling a drilled hole out bigger but with a z move also.
Start at the center. A line move so you can activate cutter comp. Arc into the final diameter to minimize cutter shock and flex. A circle at the final diameter. Then lead out like you led into it.
if R = the radius of the final cut, and the center is at X0 Y0.
G0 X0 Y0
G1 Z(full hole depth)
G1 G41 X(1/2R) Y(1/2R)
G3 X(R) Y0 J(1/2R)
G3 I(-R)
G3 X(1/2R) Y(1/2R) I(-1/2R)
G1 G40 X0 Y0
G0 Z(clear)
Add your Z's to that and you have a thread mill path. I use 1 pitch in Z for the full arc, and 1/8 pitch for the lead in and out arcs.
G0 X0 Y0
G3 X(R) Y0 Z(up 1/8P) J(1/2R)
G3 I(-R) Z(up 1P)
G3 X(1/2R) Y(1/2R) Z(up 1/8P) I(-1/2R)
G1 G40 X0 Y0
G0 Z(clear)
I have thread milled thousands of parts mostly out of 316 st. st., Inconel and Hastaloy anywhere from 3/8" UN to 3/4" NPT thread depths yp to 4 diameters. I always start at the bottom of the hole, climb mill and I take two passes. the thread will not vary and the tools will not break. Depending on what manufactor I am milling with is the software that I use, just because it will give me the best tool for the application I am using at the time. They all will give you the software for free when you buy their tools.
