Old 06-07-2011, 04:05 PM
fred norris is on a distinguished road
Drill cycle on a Fanuc 11m control in a Kuraki boring mill
The normal program drills with the quil or "w" since it is a boring mill.
G83 x1. y1. w-1.340 Q .1 R.1 F2.
I'm looking to get a closer rapid return than .1 and it won't read a "P.02" for instance. Any help is much appreciated. Thanks.
Old 06-09-2011, 08:04 AM
dcoupar's Avatar
My 11M-A manual says that the return distance for G83 is set by parameter #6211. P is a dwell time at the bottom of the hole in G82, G88 and G89.
canned cycle for lathe with fanuc control JPann G-Code Programing 6 09-27-2011 12:45 PM
Newbie- Drill cycle for FANUC slowhandd Commercial CNC Wood Routers 0 02-25-2008 10:02 PM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
Canned Cycle G73 Om Control Fanuc(drill) marrieche Fanuc 1 03-05-2007 04:51 PM
fanuc 15i problems with g81 canned drill cycle KyDeano Fanuc 2 01-20-2006 01:39 PM
