Old 08-30-2005, 08:16 AM
lazza is on a distinguished road
3D surface sub-routine
Can someone please refresh my memory?
I have several 3D surface pgms I'd like to set up a sub routines...they are programed in absolute...do I need to re-program them as incremental pgms to use as subs? Thanks in advance....
Old 08-30-2005, 08:44 AM
HuFlungDung's Avatar
Moderator
It depends on what you are doing. Often, you can rerun a program in absolute, starting at a new work shift coordinate. This would require that you call new work shifts in your main program. The standard work shifts start at G54 and go to G59, and some controllers have even more available.
You can also use G92 calls in the main mill program, providing you return to home between each new call to the subroutine.
That is only some general guidance, because there could be many different things that you are trying to do with your subroutine. If you have many simple operations to perform at many locations in one part, then reprogramming the sub in incremental can be the way to go.
Old 08-30-2005, 08:58 AM
These are pretty complicated surface programs...I think you're right about using different work cords....will try that...thanks
