| G-Code Programing Discuss G-code programing and problems here! |
what are the I's and J's in my code? G90 M99:WJET G00X10.328Y4.25 M04 F240. G02X10.328Y4.25I10.J4.25 M03 G00X14.394Y5.934 M04 F240. G02X14.394Y5.934I14.066J5.934 M03 G00X16.078Y10. M04 F240. G02X16.078Y10.I15.75J10. M03 G00X14.394Y14.066 M04 F240. G02X14.394Y14.066I14.066J14.066 M03 G00X10.328Y15.75 M04 F240. G02X10.328Y15.75I10.J15.75 M03 G00X6.262Y14.066 M04 F240. G02X6.262Y14.066I5.934J14.066 M03 G00X4.578Y10. M04 F240. G02X4.578Y10.I4.25J10. M03 G00X6.262Y5.934 M04 F240. G02X6.262Y5.934I5.934J5.934 M03 G00X14.406Y10. M04 F240. G02X14.406Y10.I10.J10. M03 G00X12.736Y19.541 M04 F240. G01X12.756Y19.612 G02X12.955Y19.553I10.J10. G02X13.325Y19.01I12.829J19.07 G03X15.55Y18.228I14.54J18.91 G01X15.592Y18.29 G02X15.762Y18.173I10.J10. G02X15.947Y17.541I15.493J17.751 G03X17.821Y16.111I17.071J17.071 G01X17.88Y16.156 G02X18.006Y15.992I10.J10. G02X17.986Y15.335I17.619J15.675 G03X19.327Y13.395I18.91J14.54 G01X19.397Y13.42 G02X19.466Y13.225I10.J10. G02X19.244Y12.606I19.J13.042 G03X19.919Y10.346I19.877J11.564 G01X19.994Y10.349 G02X19.999Y10.142I10.J10. G02X19.596Y9.622I19.5J10.112 G03X19.541Y7.264I19.877J8.436 G01X19.612Y7.243 G02X19.553Y7.045I10.J10. G02X19.01Y6.675I19.07J7.171 G03X18.228Y4.45I18.91J5.46 G01X18.29Y4.408 G02X18.173Y4.238I10.J10. G02X17.541Y4.053I17.751J4.507 G03X16.111Y2.178I17.071J2.929 G01X16.156Y2.12 G02X15.992Y1.994I10.J10. G02X15.335Y2.014I15.675J2.38 G03X13.395Y.673I14.54J1.09 G01X13.42Y.603 G02X13.225Y.534I10.J10. G02X12.606Y.756I13.042J1. G03X10.346Y.08I11.564J.123 G01X10.349Y.006 G02X10.142Y.001I10.J10. G02X9.622Y.403I10.112J.5 G03X7.264Y.459I8.436J.123 G01X7.243Y.387 G02X7.045Y.446I10.J10. G02X6.675Y.99I7.171J.93 G03X4.45Y1.771I5.46J1.09 G01X4.408Y1.71 G02X4.238Y1.827I10.J10. G02X4.053Y2.459I4.507J2.248 G03X2.178Y3.889I2.929J2.929 G01X2.12Y3.843 G02X1.994Y4.008I10.J10. G02X2.014Y4.665I2.38J4.325 G03X.673Y6.605I1.09J5.46 G01X.603Y6.58 G02X.534Y6.775I10.J10. G02X.756Y7.394I1.J6.957 G03X.08Y9.654I.123J8.436 G01X.006Y9.651 G02X.001Y9.858I10.J10. G02X.403Y10.378I.5J9.888 G03X.459Y12.736I.123J11.564 G01X.387Y12.756 G02X.446Y12.955I10.J10. G02X.99Y13.325I.93J12.829 G03X1.771Y15.55I1.09J14.54 G01X1.71Y15.592 G02X1.827Y15.762I10.J10. G02X2.459Y15.947I2.248J15.493 G03X3.889Y17.821I2.929J17.071 G01X3.843Y17.88 G02X4.008Y18.006I10.J10. G02X4.665Y17.986I4.325J17.619 G03X6.605Y19.327I5.46J18.91 G01X6.58Y19.397 G02X6.775Y19.466I10.J10. G02X7.394Y19.244I6.957J19. G03X9.654Y19.919I8.436J19.877 G01X9.651Y19.994 G02X9.858Y19.999I10.J10. G02X10.378Y19.596I9.888J19.5 G03X12.754Y19.613I11.564J19.877 M03 G00X9.858Y19.999 M04 F240. G02X10.378Y19.596I9.888J19.5 M03 M30 |
__________________ Software For Metalworking http://closetolerancesoftware.com |
| the I's J's and K's are coordinates that match up with X, Y and Z respectively, and , depending on how your controller uses them, they are either; 1) the distance from the STAR of the arc to the Center of the arc you are cutting, OR 2) the coordinates of the center of the arc you are cutting. If they seem like crazy, odd numbers then they are probably number 1 above. CHeck your controller handbook to see what your controller is expecting. |
| I's and J's I can understand but the program is for a waterjet cutter and has M03 and M04 which to me are spindle forward and spindle reverse. What the **** does M04 do on a water jet? Suck the water back up!!! That would be a trick. |
| Underdog, Your point#1 is something I have never seen: the machine is always positioned at the start of the arc (obviously), so the G02 or G03 code contains the XY coordinates of the endpoint after the arc is traversed, and I and J are the XY coordinates of the arc center. That being said, the arc center coordinates are sometimes reckoned as absolute coordinates (relative to the part X0Y0), but more often, they are reckoned as incremental coordinates relative to the start point (current position) of the machine. If that's what you meant, then good
#10
| HuFlungDung, I think we're saying the same thing aren't we? Its seems the machine builders have gone in 'generations' - I worked on one ancient machine that was ONLY incremental - Yuk! Then there was absolute and the programmers looked on it and said it was good, but the I's and J's were still incremental distances from the start of the arc to the arc center ( we're talking slightly less ancient machine now). Then the I's and J's became the absolute coordinates of the arc center (making more sense now- and easier to do standing at the machine) and finally, probably in response to howls of anguish from us - we have the R radius value. Thats how I've seen it unfold. |
#11
| I can only recall personally using a few controls that allowed absolute coordinates for arc centers - specifically the old Bridgeport BOSS 5, the G & L 2300, and some of the older Cincinnati Milacron models (cut me some slack, it's been a while). I'm sure there are more - what are others you've used? I remember some older controls ( late 70's - early 80's) such as Okuma 2200's and Fanuc 6's using signed incremental distance from start point to center point. I think the Fanuc already had the option for the R. The Bendix 5 control on a Monarch VMC75 I worked with used the unsigned incremental distance, as I remember. For manual programming, I never saw an advantage in the R or the absolute coordinates over the IJ/IK method. You had to calculate the two legs of the triangle with any of the methods to get all the info you needed to determine the start and end points, plus location of the arc center. Variety in available features and programming styles is definitely the theme in CNC.
#12
| On our new deckel maho mills with a heidenhein controls, i,j,k is an absolute X,Y,Z coordinate for center of arc. on our mazaks, its an incremental distance from the start of the arc to then end on our mori seiki's it and incremental distance from the start of the arc to the center of the arc. welcome to the frustrating world of programming.
__________________ www.cncfusion.com CNC kits for Sieg mills and lathes |
