Old 05-04-2011, 08:25 AM
MARK DEL TORNO is on a distinguished road
retract the boring bar
hi, i need help anybody knows what the code to control retract move on boring bar canned cycle ussually move 0.100" but i want it to move .020"
please any help is apprecciated.
Old 05-04-2011, 09:10 AM
John Bennett is on a distinguished road
Boring cycle
G89 is boring cycle. The steps would be 1) position of x and y 2) feed down (-z) 3) operation at bottom of hole 4)retract to intial z position.
It might help if you said what control and machine you are wanting boring help on and supply present code you are using, as each machine has different canned cycle input.
Old 05-04-2011, 09:19 AM
fanuc G71 CANNED CYCLE
THANKS JOHN,
we have diferent machine controls but i want to try in a turning center to open the bore (mori seiki sl 400) it run one line canned cycle ,i was reading on a diferet post that i can use "R" in the canned cycle ,sometime if i'm using a big boring bar is no much room to retract.
thanks.
Old 05-04-2011, 06:11 PM
dcoupar's Avatar
Originally Posted by MARK DEL TORNO View Post
THANKS JOHN,
thanks.
What model Fanuc do you have?
Old 05-04-2011, 06:17 PM
fanuc 18T
Old 05-08-2011, 01:46 AM
angelw is on a distinguished road
THANKS JOHN,
thanks.
Mark,
The R command for escape amount is used in the two line G71 cycle. The U and R values in the first G71 block are passed to parameters 5132 and 5133 respectively and are model and will remain unchanged until other values are specified by the U and R in this first G71 block.
The R command is not available in the one line G71 cycle (series 15 format) and the escape amount can be and is set via parameter. However, Programmable Parameter Entry via G10 is available. According, you could write a simple Macro program that includes the G10 Programmable Parameter Entry format and change the escape value held in the parameter by passing your desired value when the Macro is called. From a CNC programming perspective the G71 cycle definition would look the same with the addition of an R command to pass the escape value to the Macro program. In essence, you would have created your own G71 cycle definition and the Macro program will be called with G71.
Regards,
Bill
Indexable boring bar in boring head? Molochnik General Metalwork Discussion 8 04-15-2010 07:36 AM
Tap retract kendo Okuma 16 01-09-2010 02:11 PM
Suppress Retract ? boro_boy Mastercam 11 11-17-2009 06:05 PM
D'Andrea boring head, Solid Carbide boring bars etc. morehelium EBAY ADS 1 08-24-2009 11:19 AM
retract and feed beartrax Mastercam 3 08-11-2008 10:28 AM
