| G-Code Programing Discuss G-code programing and problems here! |
Need Help, I coded a small program but my z-axis is not going down in the part like it should. I am running a Zenbot Router with Xylotek controller. Here is my program: % N2 (RING BLANK 001) N3 G00 G17 G20 G40 G54 G80 G90 G94 N4 S2500 T1 M08 N5 G01 X0.0 Y0.0 Z.1 F8 N6 G01 Z-.015 F8 N7 G01 X0.0 Y0.343 N8 G02 X0.0 Y-0.343 I0.0 J-0.343 N9 G02 X0.0 Y0.343 I0.0 J0.343 N10 G01 X0.0 Y0.343 Z-0.030 F8 N11 G02 X0.0 Y-0.343 I0.0 J-0.343 N12 G02 X0.0 Y0.343 I0.0 J0.343 N13 G01 X0.0 Y0.343 Z-0.045 F8 N14 G02 X0.0 Y-0.343 I0.0 J-0.343 N15 G02 X0.0 Y0.343 I0.0 J0.343 N16 G01 X0.0 Y0.343 Z-0.060 F8 N17 G02 X0.0 Y-0.343 I0.0 J-0.343 N18 G02 X0.0 Y0.343 I0.0 J0.343 N19 G01 X0.0 Y0.343 Z-0.075 F8 N20 G02 X0.0 Y-0.343 I0.0 J-0.343 N21 G02 X0.0 Y0.343 I0.0 J0.343 N22 G01 X0.0 Y0.343 Z-0.090 F8 N23 G02 X0.0 Y-0.343 I0.0 J-0.343 N24 G02 X0.0 Y0.343 I0.0 J0.343 N25 G01 X0.0 Y0.343 Z-0.105 F8 N26 G02 X0.0 Y-0.343 I0.0 J-0.343 N27 G02 X0.0 Y0.343 I0.0 J0.343 N28 G01 X0.0 Y0.343 Z-0.120 F8 N29 G02 X0.0 Y-0.343 I0.0 J-0.343 N30 G02 X0.0 Y0.343 I0.0 J0.343 N31 G01 X0.0 Y0.343 Z-0.135 F8 N32 G02 X0.0 Y-0.343 I0.0 J-0.343 N33 G02 X0.0 Y0.343 I0.0 J0.343 N34 G01 X0.0 Y0.343 Z-0.150 F8 N35 G02 X0.0 Y-0.343 I0.0 J-0.343 N36 G02 X0.0 Y0.343 I0.0 J0.343 N37 G01 X0.0 Y0.343 Z-0.165 F8 N38 G02 X0.0 Y-0.343 I0.0 J-0.343 N39 G02 X0.0 Y0.343 I0.0 J0.343 N40 G01 X0.0 Y0.343 Z-0.180 F8 N41 G02 X0.0 Y-0.343 I0.0 J-0.343 N42 G02 X0.0 Y0.343 I0.0 J0.343 N43 G01 X0.0 Y0.343 Z-0.195 F8 N44 G02 X0.0 Y-0.343 I0.0 J-0.343 N45 G02 X0.0 Y0.343 I0.0 J0.343 N46 G01 X0.0 Y0.343 Z-0.210 F8 N47 G02 X0.0 Y-0.343 I0.0 J-0.343 N48 G02 X0.0 Y0.343 I0.0 J0.343 N49 G01 X0.0 Y0.343 Z-0.225 F8 N50 G02 X0.0 Y-0.343 I0.0 J-0.343 N51 G02 X0.0 Y0.343 I0.0 J0.343 N52 G01 X0.0 Y0.343 Z-0.240 F8 N53 G02 X0.0 Y-0.343 I0.0 J-0.343 N54 G02 X0.0 Y0.343 I0.0 J0.343 N55 G01 X0.0 Y0.343 Z-0.248 F8 N56 G02 X0.0 Y-0.343 I0.0 J-0.343 N57 G02 X0.0 Y0.343 I0.0 J0.343 N58 G00 Z0.5 F12 N59 G00 X0.0 Y0.0 N60 M30 Any help would be appreciated. I have a 2yr Certificate and as far as i know any G-code used next like a G01 will Cancel a G02 move. The z axis decends to the first mark but no more after that. |
| I bet you can't jog down either, or the z inhibit is enabled, or you have a hardware problem. Code looks OK
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Nothing wrong with the program. It is some sort of hardware, or setup problem. Router, mill, lathe, whatever. Another digitally driven mystery need solving.
| If the Z axis DRO is changing, then it's an electrical or mechanical problem. If the DRO does NOT change, then you don't have the Z axis setup properly in Mach3.
| Need Help!- Converting a pdf file to UG part file | gaoxingdcf | UG NX | 1 | 05-19-2010 07:47 PM |
| converting a .sldprt solidworks file into a .stp or parasolid file | avogtster | Solidworks | 3 | 02-26-2010 01:40 AM |
| converting a mastercam 9 file into a Solidworks file | Michael82 | Solidworks | 5 | 04-17-2009 01:14 PM |
| Need Help!- Need a favor. STL converted to part file or solidworks part file. | Cmzwirner | Solidworks | 3 | 12-11-2008 07:45 AM |
| CAD file to CNC | sc351cobra | General CAM Discussion | 0 | 12-18-2006 03:07 PM |
