Old 04-25-2011, 12:06 PM
camtd is on a distinguished road
Calculating CL to X,Y,Z,B and C movement
I have a part that has a compound hole to be drilled. I calculated the angles from the machinist hand book to verify my code for the angles.
I was wondering if there a formula to calculate CL data outside of a post processer to check on areas as needed.
Ex.
GOTO / 2.14373, 0.51450, 1.50000, $
0.37144886, 0.65651571, 0.65651571
Calulate to following and compare results for the machine G code.
G0 X-0.1444 Y-1.6124 B48.965 C60.499
Thank You
Need Help!- calculating???? cd2 Solidworks 8 03-21-2011 09:24 PM
help on calculating power needs 15mgtar General Electronics Discussion 0 08-21-2009 07:05 AM
Help calculating load on a nut Brenck Mechanical Calculations/Engineering Design 3 05-04-2009 10:29 AM
Need help on calculating steps rustamd Mach Software (ArtSoft software) 17 08-03-2007 07:08 AM
Help calculating power please? Oldmanandhistoy General Electronics Discussion 20 05-30-2007 10:00 AM
