Old 04-16-2011, 03:53 PM
bobancurug's Avatar
bobancurug is on a distinguished road
Need help with G75 code on Fanuc 10
Hello!
I have a problem with the code G75 on the machine Takisawa TC-3 with the Fanuc 10 system.
The program is already used on the machine Takisawa TC-3 with system
Fanuc 0 and worked without any problems.
When I switched to another machine with the Fanuc 10 system , G75 does not work.
This is part of the program with the G75 where the machine stopped without an alarm, just a stop.
M1
G50X162.36Z247.98S1500
G0G99G96S110T0707M16
X85.Z2.M3
Z-55.8M8
G75R100
G75X70.P300F0.07
G0Z-52.2
G75R200
G75X70.Z-17.65P500Q3612R39F0.11
G0Z-17.65
G1X70.5F0.3
G75R100
G75X55.5P300F0.07
G0Z-21.35
G75X55.5Z-52.2P500Q3612R39F0.11
G0X83.
Z-55.8
G1X70.5F0.3
G75R150
G75X54.5P400F0.12
G0X100.
Z10.
X162.36Z247.98T0000
M1
Is it something that I need to change in the program or the problem may be in the parameters?
Thanks in advance for your responses!
Old 04-16-2011, 07:10 PM
angelw is on a distinguished road
Originally Posted by bobancurug View Post
Hello!
M1
X85.Z2.M3
Z-55.8M8
G75R100
G75X70.P300F0.07
G0Z-52.2
G75R200
G0Z-17.65
G1X70.5F0.3
G75R100
G75X55.5P300F0.07
G0Z-21.35
G0X83.
Z-55.8
G1X70.5F0.3
G75R150
G75X54.5P400F0.12
G0X100.
Z10.
X162.36Z247.98T0000
M1
The format for the O series control uses two lines for the G75 cycle, whereas the 10 series control only uses one block.
The R value in the first line of the O series format sets the Return amount between pecks and is a modal value. This value can also be set in parameter #722 in the O series and remains until changed by specifying another value with G75 R in the program. Accordingly, if you wanted the two machines to have a similar one line format, and you're happy to have a constant retract amount across all G75 applications used with the O series machine, the value can be set in the parameter and the first G75 line in the cycle omitted. However, the series O and 10 control use a different syntax in the main G75 block. Therfore, the programs aren't transportable between the two controls.
The syntax for the G75 cycle for the 10 series machine is as follows:
G75 X(U).... Z(W).... I.... K.... F.... D.... Where:
X = Finish point in X
Z = Finish point in Z
U = Incremental value of X
W = Incremental value of Z
I = Step across movement in Z direction
K = Depth of cut in the X direction
F = Feed rate
D = Relief amount for the tool at the end of the cut in Z.
In the above format, Z,I and D are used if the cycle is to be used to machine a groove wider than the width of the grooving tool, or for a series of holes where the pitch of the holes will be described by I and the last hole coordinate by Z.
1. When used for any drilling operation, parameter D is omitted.
2. When used to drill a single hole Z,I and D are omitted. When omitted, the D parameter is assumes to have a value of zero, and Z and I are ignored in software.
The Return amount set by R in the first G75 line of the O series control format, is set in parameter #6217 of the 10 series control. Unlike the O series, this is the only way the Return amount can be set on a 10 series machine.
Regards,
Bill
Old 04-16-2011, 07:40 PM
bobancurug's Avatar
Thanks Bill for this excellent explanation, tomorrow I'll try to rewrite the program, and also to try that with changing parameters
Thanks again,
Boban
Old 04-19-2011, 12:48 AM
sinha_nsit is on a distinguished road
R in the first block should be in mm/inch, not in micron/thou.
Old 10-07-2011, 08:17 AM
ESP666 is on a distinguished road
Can anyone explain what the Q & P values in this line actually mean?
The G75 lines that Im looking at have the format:
G75 X Z P Q F
Cheers for your help!
Old 10-07-2011, 09:34 AM
G75 X Z P Q F
G75 canned cycle can be used for grooving or drilling in the X axis. The P and Q have the following meanings:
1, P = the peck amount before retracting to chip break.
2. Q = the side steps along the Z axis in a grooving operation, or it could be used as the pitch between holes in the Z axis if being used in a drilling operation. Note: If used in a drilling operation, R must be assigned zero.
sinha The R in the first block is saved in parameter #722 and is model, ie. the value stays the same until a different value is specified in a G75 block, or changed via MDI. Its stored in units of 0.001mm or 0.0001inches, depending on the configuration of the machine; the range is 0 to 99999999. Unless the control is configured to use Calculator style decimal input (selectable via parameter) the R value in the first G75 block can in fact be specified either with or without a period. If no period is used, the value is considered in terms of the number of least input units.
Whilst there are some arguments that must be specified without a period, all dimensional addresses such as X(U), Z(W), I, J, K, R etc can be specified without a period provided they are padded with the correct number of "0" so that a true representation of the intended value is preserved
Regards,
Bill
Old 10-08-2011, 06:41 AM
With calculator-type setting, R should be in mm/inch.
Is it correct now?
Old 10-26-2011, 02:24 AM
Thanks Bill!
Need Help!- My Milling OKK with fanuc 6M can't recognize G-code & M-code nessei Fanuc 4 03-29-2011 08:39 AM
fanuc program code vs. Haas code sixty8frbrd Fanuc 6 03-10-2011 09:05 PM
Converting Fanuc G code to Seimens 840D G code Jasbinder Siemens Sinumerik CNC controls 2 02-20-2011 10:02 AM
Need Help!- fanuc OT 401 code dc123 Fanuc 2 12-31-2010 12:48 AM
Fanuc M-Code bz1801 Fanuc 6 09-28-2005 11:42 AM
