| G-Code Programing Discuss G-code programing and problems here! |
| Choose the rpm to suit the desired cutting velocity. Cutting velocity (approx) = ND/300 m/min where D is diameter in mm, or equal to ND/4 ft/min where D is in inch. Need not worry about the feed. Just specify pitch (F-word in a threading cycle); the control would automatically calculate the required feedrate. |
| The formula to calculate the RPM using an imperial (inch) system is as follows: RPM = CS X 12 / pi /D Where: CS = Material Surface Speed for given cutting tool material D = Workpiece Diameter pi = mathematical constant (3.143 approximately) 1. Surface speed (CS) is normally specified in feet/min or meters/min. 2. Rotating cutting tools and workpiece diameters are normally specified in inches or mm. Because items in 1 and 2 are specified in different units, one must be converted to the units used in the other. Accordingly, that's the reason for multiplying CS by 12 in the formula above; to convert feet/min to the same units used to specify the workpiece diameter D. This formula can be simplified by dividing 12 by pi to obtain a constant to use in the formula. 12/pi = 3.8197 The formula for imperial calculations becomes: RPM = CS X 3.8197/D and can be further simplified by rounding 3.8197 to 4.0 to obtain a close approximation. RPM = CS X 4/D As mentioned earlier, there are other factors to consider. The slide velocity of the carriage carrying the cutting tool is a product of the RPM and the feed rate in feed/spindle revolutions; in the case of a screw thread, the lead of the thread. The slide velocity must not exceed the maximum slide velocity specified for the machine, in most instances this will be the Rapid Traverse speed of the machine. Once the RPM has been calculated using the above formula, multiply the result by the lead of the thread; for a single start thread this will be the same as the pitch, and compare the result with the maximum allowable slide velocity of the machine to ensure that its not being exceeded. An error in the thread lead occurs when the slide accelerates from zero to the correct slide velocity at the beginning of the thread, and during deceleration to Zero at the end of the thread. The length of the Acceleration/Deceleration zones increase as the RPM and thread lead increases. The error resulting from Acceleration/Deceleration is control specific, but must be considered when programming the start position of the threading tool and how large an undercut into which to run the tool at the end of the thread. Sometimes there will have to be a compromise between the RPM for the best cutting speed and factors such as maximum slide velocity and slide Acceleration/Deceleration. Regards, Bill |
| You can calculate the maximum RPM for any particular lead of thread`using the following formula for an imperial set machine. RPM = MV X 12 / TL Where: MV = Maximum slide velocity of the machine in Feet/Min TL = Thread Lead Lets say that the machine has a Z Rapid Travers speed of 32 feet per minute (10 meters per minute approx.) and that the lead of the thread`is as in your example, 13 TPI (0.0769"), then the formula would be: RPM = 32 X 12 / 0.0769 RPM = 4993 Using your example of 1/2 13 thread in aluminum, and a surface speed of, say, 1400 f/min, then using the formula: RPM = CS X 12 / pi /D Where: CS = Material Surface Speed in f/min D = Workpiece Diameter pi = mathematical constant (3.143 approximately) You get the following: RPM = 1400 X 12 / pi / .5 RPM = 10,695 As can be seen from the above, the resulting RPM is way in excess of the max RPM that can be used with a feed rate of 0.0769" per rev for a machine with a max slide velocity of 32f/min. Regards, Bill |
| Formula to calculate facing time in a lathe? | mattslay | General Metal Working Machines | 9 | 09-25-2009 11:32 AM |
| Mach3 Lathe Thread | Kelinginc | Mach Lathe | 1 | 05-31-2009 06:53 PM |
| Need Help!- Thread Formula - Changing Speed | treyance | General Metalwork Discussion | 2 | 05-08-2008 07:47 PM |
| Need Help!- thread milling on lathe | Bigbill | Mastercam | 2 | 04-10-2008 12:06 PM |
| New Formula`s Thread | max_imum2000 | Mechanical Calculations/Engineering Design | 8 | 04-07-2007 05:31 PM |
