Old 03-12-2011, 10:56 AM
A_C_L_Barney is on a distinguished road
Using G41/2 on 5-Axis Path
Anyone know how to calculate the error that we might see if we use 3Axis compensation (G41/2) on a 5Axis tool path?
We are machining at a maximum angle of 6.2 degrees from vertical so it will be very small over a cutter comp of 0.5mm.
My first thoughts were [Error=Cutter offset * Sine(Angle from vertical)]
Anyone had experience of this before?
Just for ref. we're not talking precision engineering here (+/-1mm) and the surface is probed to get the finished size right so it will work even if we ignore the error.
Old 03-12-2011, 02:58 PM
Chrliev is on a distinguished road
I have never heard of 3D, 3-Axis or 5-Axis tool compensation using G41/G42...
Going back to the early 80's Fanuc 3 and 5, Cincinatti Acramatic and GE550 and 1050 series controllers, every machine that I have ever worked on had 2 axis toolpath compensation, though some were very complicated to use.
How would 3D tool comp work if I was using something like a 1" (25mm) bullnose cutter, with a .125" (3mm) radius, cutting accross a series of 3D surfaces. I am not sure how the controller would know if the corner radius or the flutes of the cutter were contacting the part surface. Even using a ballnose cutter it would be impossible to know where the ball was contacting up onto surfaces as the contact point would change constantly.
I can't even imagine how 5-Axis tool motion can be compensated. It would be nearly impossible to do 3D or 5-Axis comp, without being able to know what the entire surface looked like the way a programming system knows and calculates centerline files applied to the entire surface.
You didn't say what CNC machine or controller you are using, maybe I have missed something these last 30 years...?
Old 03-13-2011, 01:17 AM
Superman's Avatar
Superman is on a distinguished road
The basic cutter comp only works in the plane ( G17/G18/G19 ) that is set before starting the pass ( G17 is X & Y ), the other axes do not have the comp applied.
Many controls do not allow plane changing whilst comp is active.
Some have an additional G-code for 3D comp, I have seen a G43 on Okuma controls. I think 3D comp is mainly used with a ball nose cutter, and run best when programmed to the centre of the ball. It may be an purchased option as well.
High end, 5 axis machines can have comp applied to toolpaths, but these may need special CADCAM posts to output the right code.
our Heidenhain ( MilPlus control ) could do it, but "vectors" are required with the XYZ co-ordinates.
You may be able to "fudge" the path, but remember that the other axes don't have comp on them
4-Axis CAM and Tool Path Problem skibbey General CAM Discussion 6 03-13-2007 10:05 AM
C axis tool path Capt Crunch Mastercam 1 12-20-2006 07:05 PM
Change - from linear path control to CNC path control fidibus42 General Electronics Discussion 1 12-04-2005 10:43 AM
need help fast 5 axis tool path in mastercam fasttom G-Code Programing 0 12-02-2005 12:22 AM
4 Axis EDM software , used to create foam cutting path? bgriggs Foam Cutting Software 1 09-29-2005 04:52 AM
