Old 01-27-2011, 03:13 PM
pcb-101 is on a distinguished road
retract rates
i am trying to figure out how to control the retract rate on a Haas VF 2YT
Old 01-31-2011, 02:02 PM
camsys is on a distinguished road
I'm not sure about HAAS, but Mistubishi and other controllers do it through
their on-board system parameters.
My guess is that HAAS might have similar system level settings
Old 01-31-2011, 05:04 PM
dcoupar's Avatar
What retract rate? From the bottom of a hole during canned cycles?
Old 02-01-2011, 05:52 AM
sinha_nsit is on a distinguished road
On a lathe?
Old 02-01-2011, 08:47 AM
dcoupar's Avatar
Originally Posted by sinha_nsit View Post
On a lathe?
He said it was a VF 2YT in his original post. That's a mill.
Old 02-01-2011, 10:05 PM
Usually, the retraction is rapid in drilling cycles, at feedrate in boring cycles/tapping, and at multiples of feedrate (up to 20xF, depending on parameter settings) in rigid tapping. This is for Fanuc. On Haas also similar things might be there.
Old 02-01-2011, 10:32 PM
If you are meaning the tapping retract rate it is Setting 130 which can be 0 or 1 for a normal retract rate. 2, 3 etc retracts 2 or 3 times as fast. Alternatively you can have a Jvalue in the G84 command and this over-rides whatever is in Setting 130
Need Help!- Retract between cuts hpowell BobCad-Cam 5 10-18-2010 12:27 PM
Tap retract kendo Okuma 16 01-09-2010 02:11 PM
Suppress Retract ? boro_boy Mastercam 11 11-17-2009 06:05 PM
G81 RETRACT HIEGHT? panaceabea Haas Mills 1 05-14-2009 04:27 PM
Retract Height Sanghera SheetCam 1 05-29-2005 11:52 PM
